Trailering an unfinished Bronco?
Jaybr
Hey folks, I have a situation I'd like your opinion on. We bought a new place a few months ago, had a new shop built and remodeled the house and where back and forth between the old and new places for a while. We had movers move the furniture, but I didn't want them touching my tools or broncos so I've been going back and forth bringing trailer loads to the new place. My 73' Bronco, which is close to being finished is still at the old place and I'm hesitant to trailer it on my open car trailer in it's current state. My concern is: I've installed the hard top glass, but not the windshield or door glass, or the latch on the hardtop back window. I'm worried that without the windshield there will be too much wind blowing in the front and could blow out the hardtop glass. Are my concerns warranted, or should I throw it on the trailer and send it?
The new place is 3 hours from the old and there is some 70mph highway involved with most of the drive 55mph speed limits.
I'm working solo and arranging help to install the windshield has been a challenge
Jaybr
Jaybr
What will the tongue weight be if you back Bronco onto trailer?
Good question. I have considered towing backwards and could probably make it work. Trailer is 18' so I have some room to move it around for balance. I normally place the front wheels in front of the trailer wheels and everything is fine, I do have a lot of room in front of the bronco in that situation. I also have a weight distribution hitch, so could back it pretty far forward on the trailer without much worry.
Cool67
Opened trailer my Bronco 1600 miles backwards just pull it on as far as possible
Scotty
You could rent an enclosed trailer, but I don't know how to find comfort at highway speeds not knowing if bearings are greased and tires are good.
Turo for trailers: Towlos or NeighborsTrailer
ep67bro
Bronco Junky
Easton, MD
Tow it back wards or put a piece of plywood in the windshield opening and tow it the normal way.
jamesroney
Fremont, CA
Unbolt the liftgate and take it off. The remaining glass will be parallel to the airflow, with no possibility of positive pressure blowing out anything.
If you can't easily unbolt it, just replace the lift struts with something solid, and bolt it wide open. Don't be tempted to run it with the liftgate up...because it will bounce it self closed.
AZ73
Remove the lift gate like James said. Mine was towed flatbed for 2 hours like this, with full drivetrain. No glass in the windshield, doors or sides of the top but without the liftgate the air will flow through even with the side glass. I think the lift gate is like 2 hinges with 4 screws each.
Jaybr
Jaybr
Made it back to the old place last night and a buddy came over today and we got the windshield installed. The rest of the things I need to do to get it ready to trailer are easy enough solo jobs.
Appreciate the advice!
Jaybr
Jaybr
Finally got it moved to its new home, hopefully next time it moves will be under its own power
