Tranny Temp Sending Unit and Gage
tonto
An Autometer mechanical gage with the sending unit in the pan.
Another idea I always liked was an electric gage with a toggle switch and two sending units one in the pan and one in the line two the cooler to switch between and compare.
Hnrys69
B and M trans guage from summit, has 2 differant size T connector parts that you put on your line to the trans cooler depending what size yours is... It works great and took me about 15-20min to install the whole thing :)
Dusty
I agree with Francois (Tonto). I bought an aluminum bung and welded it into my TCI deep pan for the mechanical gauge sender. The tranny gets its fluid from the pan so that's where I want to measure it.
Dusty
74bronc
I got an external Oil filter that goes in the line to the cooler and it has a hole for the temp sender. That is where I am going to get the reading from. There is alot of debate out there about where is the best place to take the temp. I think the pan or the line to the cooler are perfectly adequate.
