tranny temp sending unit question
76 explorer
oklahoma city
ive never put a tranny temp gauge in a vehicle but i think it would be a good idea to put one in my bronco since it will see some extreme use compared to the other vehicles ive had.
what is the best/easiest (is that an oxymoron?)way to put the sending unit in my tranny? ill probably be dropping my pan again soon and figured that would probably be the best time to do this.
CrazyHorse70
Austin
I mounted a remote spin-on filter on the pass. side fender well under the hood and put the temp. sensor into the inlet side, (before the fluid goes to the filter) to get a temp. reading there. From the filter the fluid goes to a trans. cooler mounted in front of the radiator. Works good for me. With the remote filter you can change the filter and not have to pull the pan.
72Sport
Silver solder or weld a female fitting in the side of the pan in an area where the sending unit won't hit anything when you screw it in. A reducing bushing works well. Wait til you get the gauge so you don't have to do it twice.
When it is in the pan your reading the temp before it goes through the trans.
Dusty
I agree with taking the temp in the pan. Autometer sells aluminum or steel weld-in bungs that accept the autometer mechanical gauge sensors. Here's mine:
Dusty
Set the laptop on the passenger seat
Plug it into the transmission controller
Turn it on
Read the digital display
note: this only works if you have a computer controlled transmission;D
I just couldn't resist
76 explorer
76 explorer
oklahoma city
Turn it on
blar blar blar :)
thanks for the ideas fellas
