Trans tunnel hole different for t shift vs j shift.
fordguy
I am changing to a t shift from a j. Can I work with the current opening or do i need to fill it and start over
JB Fab
It should not be a problem at all.......
The " T" shift hole is larger, but in the same location....
There was some overlap in 72', when they were changing to the "J" type shifter but the bodys had a "T" type hole.
fordguy
fordguy
thanks JB. how much bigger will the hole have to be for your twin sticks. iam going 4R70W.
JB Fab
you might need to enlarge the hole 1" to 1-1/2" to the rear, but wait until you install it before you do any cutting?
Cheers,
Jon
