trans tunnel holes
tatersalad
I have owned 2 different broncos that have had around 1 1/2 holes in the upper forward part of both sides of the transmission tunnel . Just wondering what they were. My thoughts are old school AC line routing. I'll post a pic.
Scoop
Bronco Old Fart
Cuchara, CO
More than likely old AC hoses as you're suggesting. Although 1 1/2" are pretty big for this.
spap
I have the same holes two up top and one for the drain.
Found some nice rubber plugs to cover them
On the drain the PO just basically took something sharp and hammed a hole through.
Haaa nice
tatersalad
tatersalad
Try it again
Scoop
Bronco Old Fart
Cuchara, CO
Those are in the right position for AC condensation drain lines. Just plug them as suggested above.
bigmuddy
Marthasville Missouri
Been talked a lot around here. general consensus is AC drain holes.
My bronco had dealer installed AC and the drain was in that area. I think the dealer tech just to punch and hammered a hole through were he thought it needed to be and moved on.
tatersalad
tatersalad
I've never seen a post on it before but then again I haven't been as active on the site in the last 5 to 6 years as I was before. I kind of go in phases. My thoughts were always AC line routing though.
