transfer case not shifting
valveamp
Hi. I have a Dana 20 with the twin stick mod. Originally, it was a T-shift transfer case. It' been a couple years since I've needed to run in 4WD. Last Sunday, I broke my rear drive shaft. At the time, I thought I would drive back home in front wheel drive. However, I couldn't get it into front drive high range. I did manage to get it into front drive low by shifting the rear into low first, then the front and, lastly, the rear back to neutral. This didn't work for front high range. This weekend, I replaced both front and rear drive shafts. At that time, I couldn't get the front into either low or high range. It just wouldn't shift. Rear shifts just fine. I know that shifting the transfer case can be troublesome, but I've always managed to get it in, but not this time. Any thoughts as to why the rear shifts fine but not the front? I hope I don't need to open the case. Thanks.
SHX669
Well I was going to ask this same question in a couple of days.
I've got everything but front hi .
How bout I add a question - can I fix any potential issues by working through the access plate without dropping the TC ?
Viperwolf1
electron whisperer
As originally built, the t-shift D20 has a very specific shift sequence. The rear side must be shifted into high or low before the front can be shifted into the same range. When disengaging the front, it must be shifted to neutral before the rear side can change ranges. This is due to the action of the shift rails and the 2 interlock pins inside the tcase. When changing to a twin stick shifter this sequence doesn't change. If you want independent shifting of the front and rear you must either modify the shift rails or remove the interlock pins.
SHX669
I've tried every combination with the "rear lever" that i can think of but can't get the FRONT into Hi. I can get it to shift into the other positions - neutral and low.
Other than the normal rocking back and forth I've never had trouble shifting in and out of 4 wheel drive UNTIL 3-4 months ago . I couldn't shift out of 4 hi even with the usual coaxing so i had to unlock the hubs and use more than the normal force on the shift lever to get the front to disengage. I'm wondering if I bent the shift forks or maybe something internal is binding up.
Can anything be fixed by working through the inspection cover without dropping the transfer case ?
Oh - and no nothing is binding/blocking the shifter or the shift rods and no - so far rocking back and forth with the engine running hasn't helped either .
-- AND I put new bearings , seals etc. - rebuild kit a few years ago and noticed that the front " small/ hi gear' had quite a bit of wear.
Viperwolf1
electron whisperer
It would be difficult to bend the fork but more likely the fork is loose on the shift rail. It might be possible to tighten it through the bottom cover.
SHX669
Thanx for the input . I plan on pulling the inspection cover and taking a look just thought i might be more motivated if there was a 'maybe " vs a "no way" LOL
V
valveamp
Yes, I'm aware that you have to shift the rear into high first, then the front. That works for low, but not for high. If the fork was loose on the shift rail, wouldn't it affect low as well as high?
Viperwolf1
electron whisperer
Yes but the shift rail travel from neutral to low is much further due to the width of the teeth engagement. So you may only be partially engaged in low.
V
valveamp
OK, understand. If feels pretty solid, but I admit that I didn't really drive more than a few feet, recently, in front wheel low range, so you may be right, it may not be a full engagement.
redwards69
Double Oak, TX
I cannot imagine how difficult it would be, but I did have to replace one my shift forks when rebuilding my D20 as one of them was slightly bent and would not let everything line up right upon reassembly.
