Transfer Case vent options
Fitz24
Just finished rebuilding my D20 but don't like the stock vent setup. Is there an easy way to install a hose that runs up under the hood to a higher location? Is the stock vent pressed in or treaded? Looks to be just pressed in.
Steve83
It doesn't really matter. Remove it (whatever it takes), drill it for the tap, tap it for the fitting, screw the fitting in (I highly recommend a 90° elbow), and run the hose wherever you like.
Don't T hoses together from components that use different fluids (T-case gear oil X ATF).
70_Steve
Old Guy
The stock vent is press fit, and can be stuborn when you try to remove it. If I remember, the hole is already just about the right size for a 1/4" NPT tap. X2 on the 90° fitting.
DanWheeler
Kirkland, WA
hmm, i never even thought of that. shoot - another one to add to the to-do list. All my breather lines Tee into one main line that runs from the rear to the front. Guess there could be some fluid exchange on inclines.
Fitz24
Fitz24
Thanks, getting ready to put the D20 back in but better try this first. Already have the tail housing installed on the case. Need to find a way to keep shavings out of the case.
BroncoDawg
Bishop, CA
BC broncos sells a cool breather filter on a custom mount that has four connectors for breather hoses. Mounted it on the side of the tub behind the driver's seat and is high enough to not mix fluids unless I roll it, and if I do that, I got more to worry about than mixing fluids! haha!
Viperwolf1
electron whisperer
If you're going to be drilling or tapping in the vent hole just remove the output assembly and take it apart. The vent is right between the inner and outer bearing.
zerostar2410
whats wrong with the stock breather? why mod the breather? any pics or write ups on how to change the transfercase breather? i currently have the t-case out and would like to convert mine if it's better.
70_Steve
Old Guy
If you ever plan on driving through even relatively shallow water, you may want to extend the breathers on all gear cases (diffs, t-case, tranny) up higher to avoid the possibility of water getting into those area.
Not any more to modifying the transfer case breather than what's been stated in this thread already.
  1. Remove the stock breather
  2. Tap the hole for a NPT fitting
  3. Connect that fitting to a breather higher up in the Bronco.
I just bought a couple cheap breathers at Autozone. I never had one connected to the Dana44, and didn't extend the one on my NV4500 when I installed it. I do have the transfer case and 9" extended up.
zerostar2410
how exactly would i go about removing the pressed on cap on the vent? Ive never tapped of used NPT fittings. is there somewhere i can read up on this before i do it this weekend? im a noob if you cant tell
thanks.
bigbri69
tomsriver
i did mine by soaking it first than i think i poped off the mushroom cap then grabed it with vicegrips and started working it back and forth.i do remember it came out way better than i thought.maybe a 10 job.then i taped it and with i think 1/4" tap and had a 1/4 male x barb adapter and was done.im a plumber so i had all kinds or fittings on the truck.i also took off the lid of my trans cause i had a lil blow hole 4 a vent on that.drilled it out and droped the same fitting in the hole that i used on the t-case.screwed a nut up from the bottom with red locktite and then peened the threads with a small sharp flat head so the nut dont have clean threads.it wont back off now!all my vents are straped to the top of my firewall were the choke comes out.
Fitz24
Fitz24
My vent was pretty easy to get out. I had soaked the tail housing while it was apart to clean which may have made it easier. I used a pair a channel lock pliers, grabbed the vent across the top and started wiggling it. Came right out.
Since I didn't want to dismantle the tail housing again I turned the case upside down so the vent hole faced the ground. I took my 1/4" NPT (National Pipe Thead) and coated it with grease as suggested in an earlier post. That way the shaving stuck to the tap or fell to the ground. When finished, there were no shavings visible through the hole so I went ahead and turned it back upright. Now I just need to pick up some 1/4" fittings to thread in and create a 90 degree bend to clear the floor easily. Then a hose that will run up under the hood.
Done.
zerostar2410
got it! i plan on getting all parts tomorrow and doing it this weekend before i put entire drive train back in.
Im also going to be installing an NP435. Is there a breather vent on that? is it also the same process?
also, What type of tap and die set should i buy? carbon steel, titanium nitride, or alloy steel?
Steve83
Virtually every fluid chamber on a vehicle has some type of vent, and that trans is no exception.
No. The NP435 vents around its shifter, so there is no fitting to remove/replace/modify/extend. The way Ford dealt with it was to put a LARGE closed-cell foam pad around the shifter tower that 'sealed' it to the body, and let it breath through the shifter boot.
zerostar2410
one last question, sorry to hi-jack.
I just got a tap and die set from harbor freight. As previously stated, i'll be using the 1/4 threader. The set i got came with 2 1/4. one is 1/4-20 and 1/4-28. Which one do i use? and what is the 20 and 28 mean?
bronko69er
EB Addict
Renton, WA
The tap you want to use is a 1/4-18 NPT (National Pipe thead).
The ones you are looking at are straight threads (1/4" major diameter, 20 or 28 threads per inch).
Be aware that NPTs are tapered so if you cut threadstoo deep, the fitting wont seal.
Cut a little and test fit. Repeat.
zerostar2410
nevermind.. where do i get NPT tap and die set from? besides online because i want to do it this weekend.
