Transfer Case
duan447
I AM REBUILDING MY TRANSFER CASE.I NEED.I TO KNOW THE PLACEMENT OF THE 13 BEARINGS IN THE REAR OUTPUT SHAFT.THERE APPEARS TO BE A LIP IN THE SHAFT,IF I PUT THE BEARINGS BELOW THE LIP THEY ARE TOO TIGHT ABOVE TOO LOOSE.
lodnirgs
Louisiana
I recently did the same job. My thirteen rollers were placed as far into the bore as possible. I did take some jigling for them to fall into place. Do slather the area with some grease so that when in place, the rollers do not fall out. Good luck. lodnigs
