Transmission cooling lines
LouB
St. Louis
I am ready to put the engine/C4 back into my truck and will be making new cooling lines. Was planning on just buying six foot sections of 5/16 steel line from the auto parts store; but, found summit, and others have coils of aluminum line. Kicking around the idea of making them out of aluminum. Also bought a big cooler from summit. It is advertised as having 3/8 NPT Female supply and return fittings. Who sells adapters - NPT to Flare? Appreciate any suggestions or experiences.
LB
Apogee
Tangent, OR
To the best of my knowledge, there are adapter fittings to go from 5/16" tube (inverted flare) to 1/8" NPT and 1/4" NPT, but not 3/8" NPT without stepping up to 3/8" tube. You could use multiple fittings but that can be cumbersome and takes a lot more space to accomplish. Why not just run 3/8" NPT to 5/16" barb fittings and then run a piece of flexible hose between the cooler and the hard line? You would want to create a bead on the 5/16" tube for solid hose connection and sealing purposes, but that's not too tough.
Just FYI, you can buy coils of the steel line as well. I prefer it over the aluminum just because it's tougher and resists sticks and errant wrenches better.
grant_71
I used the coil of line for my fuel line, after trying to get it somewhat straight and not kinking it when i bent it (it wants to twist all the time from the residual coil) i ripped the stuff out and bought hard line from the local parts store. Yea, and stay away from the aluminum, it is meant for lightweight racing applications, but vibrations from the truck will wear it down and it will crack form fatigue. Just my .02
Grant
L
LouB
St. Louis
Thanks guys. I will receive the cooler this week and better inspect. Like Apogee said, "multiple fittings can be cumbersome" I don't want that; so, I may use barbs and short pieces of hose. You both concur on using steel over aluminum. That was my original plan and should probably stick to it.
I am not restoring this truck but putting a totally rebuilt 302, rebuilt C4, and rebuilt t-case back in. Everything is bolted together and ready to go back in. Trying to have it driveable by the end of the month.
Mark
Bronco Klutz
NW Indiana
I just redid my transmission cooler lines.
Check your local hardware store for fittings and adaptors.
Mine has just about everything I needed.
tasker
all knowing of nothing
NH
Just bent mine up yesterday, a bit of a project getting the old fittings out. I used the 60" 5/16 line. Worked fine....not perfect but came out okay.
BwoncoHowie
C-4 Wizard
For the cleaner more factory look, JBG has pre-bent Plated and stainless steel cooler lines.
On the transmission, aluminum lines are prone to crack at the flare due to vibration.
