Transmission question
Snackslinger
I bought a 4t70w from monster transmission. I was looking at the compushift controller. Their site asked for the type plug that I have. That was simple. Then it asked for what range/inhibitor switch. Analog 8 pin or digital 10 pin. The transmission doesn’t have either on it. I’m not sure what it is and if I need it. I’m running a 347 with proflo4. Any help is greatly appreciated
Bronco-Brian
Lake Oswego, OR
Hi, I'm running a 4R70W using US Shift controller. They have a guide on connectors. The one you ask about above is the selector shaft range switch. This link should help you. Ask monster what type they use, or if you have a donor (like from explorer) you can look at it to find out. BTW, I really like my quick 4 controller - check them out too.
Brian
https://www.usshift.com/downloads/connectorguide-4r70.pdf
The US Shift controller is the more common choice. Better understood around here as well. They also do the controllers for the 6 and 10 speed automatics.
The range switch, or how ford calls it the (MLPS, Manual Lever Position Sensor) is what attaches to the side of the transmission and gives you the normal neutral safety and back up switches, but for the computer it tell where you have the shifter. It is the only way for the computer to know what you want it to do. Are you in reverse, drive, manual 1st, etc.
There are 2 types. The original analog which was buggy when new. So much so that Ford gave up and put a digital version in that lasted until the end of production. You want the digital one. The digital part adds a couple of wires, so 10 wire instead of 8.
