green50gt said:
My setup is this. 75, 5.5 coils, D44 track lock, 3" body, 33" TSL's. It had 38s on it. Other than that, thats the way I bought it, so dont give me any flack.
I have to move my radius arm mounts anyway, because they are still at the stock location with the 5.5 lift coils. So I could do something there.
Thanks, Derek
Please don’t take this as I’m flaming you or being dis-respectful towards you in anyway.
Be careful with that much lift and stock width axles and what seems like you have little wheeling experience you might be a good candidate for a roll over with out a wristed arm.
My observation is you don’t really understand or didn’t when you started this thread what and how a wristed arm works, my concern is as I’ve observed some other people on the trail in the last few years break drive train and turn themselves over on there sides due to in my opinion modifications and lack of trail time behind the wheel of there rigs to get a feel for how there rigs perform with these modifications off road.
I’ve said something similar to this before, at least for me except the money spent on doing the 2nd & 3rd generations of the same upgrades, I’m glad they happened, the evolution my E.B. has gone through has afforded me the time to learn what its capable of and what’s it’s not and so far help keep me out of harms way, and help to develop something similar to our equilibrium of the inner ear, having a feel for just how off camber I can get when side hilling and not roll over for example.
My advice for you is to install a really good lift kit if doesn’t have it all ready, like from B.C. Broncos, see how much flex you really need for the kind of wheeling you will be doing, for me I have to remember to unpin my wristed arm, I believe most of the lift kits out there will give all the flex for the trail the average person needs.
And drop that lift down to a 2.5” or 3.5” suspension lift and go to if any preferably 1” or 2” body lift, and clearance that sheet metal for those big meats, my main focus right now with my E.B. is to lighten it up and get the center of gravity lower to the ground to have more fun on the off camber stuff and less fear of going over on my side.
What is the reason you are moving your radius arm mounts? You mean the ones on the axle (wedges)?
If your doing this to correct pinion angle, it will have a negative effect on your caster, and it will probably cause you to drift around in your lane on the road, just FYI in case you didn’t realize this.
Basically you can always wrist a radius arm later if you feel you need some more flex.
Here's a link with a little info
click here
Good luck, Francois.
