- May 11, 2013
- 1,760
Howdy. wrapping up a few items here prior to getting inspected. my turn signals are proving elusive. at first i thought it was because i had a mix of LED and incandescent bulbs. installed all LED retrofit and LED relays and grounded them and they all worked. then sort of out of the blue at the end of the build season last year they stopped working. this weekend i went back to all incandescent and original flasher cans. turn signals worked. also verified flasher cans by swapping between emergency and turn signal. both worked. yesterday i went on a short shakedown ride and they dont work again. horn works so i believe that the dedicated ground i ran from the column works.
WH direct fit column. painless harness. converted to ford style 1/4 round signal plug. emergency flashers work. turn cancel cam works
ideas?
thx
Hank
ideas?
thx
Hank
