- Jul 1, 2011
- 1,890
I have a Lecarra steering wheel and hub adapter that I bought from WH a long time ago. It uses roll pins to turn off the turn signal. One day one of the
roll pins broke my turn signal. Strangely enough, it broke the small lower inner "ear", not the long arm. So I pulled the roll pins and have been manually
turning off my turn signal for 10+ years.
Recently, a guy pulled out right in front of me, causing me to panic stop. After nearly t-boning the guy I look down, and sure enough my right turn signal was on.
Repairing my turn signal cancelling function moved to the top of my list.
So I install a new turn signal switch and roll pins and bingo! Turn signal cancelling! But I feared the inevitable (roll pin breaking turn signal again)
so I start reading old threads and found this link posted by thegreatjustino in a 7 year old thread. It describes a way to modify the arms so that
the small diameter roll pins don't "snag" the arms, which is what causes them to break, especially for you guys in freezing temperatures. I was
about to do mod then thought, I'll try the "real" turn off cam first. So I got one from Tom's and although it shows the one with 1 turn-off nub,
I received one with 2 turn-off nubs, and from what I read is the preferred one. Woohoo!
I obviously had to modify it, so after measuring roll pin height I ended up cutting over half the bottom off. I then wrapped the new bottom with
electrical tape to isolate it from the horn contact ring, pulled the roll pins and got it on my adapter. That's when I noticed the 2 nubs lined up
perfectly with the roll pin holes, so I tapped in 2 new roll pins. I know spring pressure would have held it in place, but no way in hell is it ever
gonna move now. Sorry for the long rant, and no post is complete without pictures.
Cheers,
Scott
Cheers,
Scott
