turn signals stopped working? park lights come on when i hit the brake? help???
broncomitch
west jordan, utah
turn signals stopped working? park lights come on when i hit the brake? heater's not working? no blown fuse's. can anyone point me where to start looking first?
Viperwolf1
electron whisperer
Check the turn signal flasher. I just replaced one.
Park lights-I'm guessing the front park lights come on? Make sure the hazard switch is off. Possible bad turn signal switch (could also explain 1st problem) or really screwed up wiring.
Heater-does it work on either speed? Check for voltage to motor and good ground connection.
broncomitch
broncomitch
west jordan, utah
well one problem fixed. lol had the hazarded switch on :-[ i really hope my turn signal switch is not broke....tho.. my steering shaft dose slide up and down....could that do it? cus they worked before i put my trans in.
Viperwolf1
electron whisperer
One fixed but you probably have one more to add. If the hazards were not flashing then they need attention too. There are 2 flashers under the dash. The one for turn signals has a blue connector. The other one is for the hazards. New flashers are cheap.
Pokey71
where about is the turn signal flasher? i could only find the emergency flasher.
RV77
Springfield,IL
Hey Mitch - Another idea on the parking lights.....Check your bulbs.I have seen elements break and touch the other element and do exactly as you describe.
