- Nov 3, 2003
- 49,442
i also noted that when i put on a turn signal, say right, with the brakes pushed, it will make the right light go out, this is also with the key off. same goes for the left side.
I mentioned this in your other thread, but no, that's normal. Same thing going on as Viperwolf said a bit ago. And the switch, being a mechanical link, will do this with the key ON or OFF. Only thing that won't work with the key OFF is the turn signals themselves.
Keep digging! We're having fun egging you on to see what else you'll dig up.
Something else. On the '69, you should have the two plugs through the firewall adjacent to the fuse block. Correct?
Disconnect the battery, pull the fuse block off the floor, un-plug the plug (from the engine compartment side if I remember?) and check all connections, wires, loom, and any other pertinent details. Make especially certain that your wires where they go through the firewall and get pressed under the fuse block itself are not frayed and breaking from age.
Pay special attention while you're in there to the main power/charge/ammeter circuit. This last is not likely to be the source of your current problem, but if anything shorts to one of those leads...
Well, you'd be kissing your whole harness goodbye most likely. And in a move that would make 22213evl proud, I got pics, so I ain't lyin.
