Ultimate Raffle Bronco!!
J
jwtrapper
Van Lear, Kentucky
We received the Gas Tank Skid Plate today. I just had to share some pictures of it. It's truly a great piece of craftsmanship. Thanks Poison Spyder!!
Fitz24
Can't wait to see the final product. Going to be quite a rig. The only way I think it would be better is if it ends up in my driveway;D
J
jwtrapper
Van Lear, Kentucky
The harnes was donated by RJM Injection but we are still needing the ECU.
If you go back a page to post #109 the wish list is updated with what we still need.
It will be finished at Nemesis on the 9th. I am hoping to pick up the axles and the Bronco and take it up to TnT after that. Cant wait to see how the cage and dash turned out.
Dusty
Justin, I forgot to tell you that you guys will need to weld up the corners on that gas tank skid. We didn't have an EB to test fit it on (Poison Spyder is a Jeep shop, and all of my Broncos have aftermarket tanks) so we just went off of your pattern but left the corners un-welded in case you need to persuade it a little to fit.
In case anyone is interested, that is a one-off gas tank skid to fit the stock tank. Poison Spyder doesn't make anything for the Bronco but we still wanted to help with this project so Justin told us what he needed and we made it up.
Dusty
J
jwtrapper
Van Lear, Kentucky
Sounds great Dusty, that won't be a problem with welding the corners up. We were discussing that when we were checking it out.
Great work and thanks again!!
J
jwtrapper
Van Lear, Kentucky
Teaser pic of the front axle. It's almost complete. Rear Axle is done, Front axle should be done in a few days. Cant wait to see them under The Bronco.
plumbdoctor
Golden
I have 2 ecu's in the garage. I will have to look to see what they are? cant remember off hand if one is an A9L... I will be back in town on fri nighr ro look
J
jwtrapper
Van Lear, Kentucky
This is going to be the 2011 Raffle Vehicle Tickets won't be available untill Jan. 2011
The 2010 Raffle Vehicle is a 1998 Jeep Cherokee w/5.5" TnT lift on 33's with lots of goodies. Tickets should be ready for it soon.
Our Donations So Far:
TnT Customs: Special Treat
Warn: Warn Winch
Tuffy Security: Security glove box and center console
Ruff Stuff: $250 worth of Parts
Seal Brothers: Paint Job
SSR Auto: Paint and supplies
Canon Tuck: 205 transfer case
Nemesis Industries: Cage, Custom Dash and some special touches
Battlement Fabrication: Rear Bumper and Tire Carrier
PRP Seats: Two of their Daily Driver bucket seats
Premier Power Welder: On Board Welder
Poison Spyder Customs: Rear Gas Tank Skid Plate
Craig Fire and Safety: First Aid Kit and Fire Extinguisher
Royal Purple: All Fluids
O'Reilly's Auto Parts: Dress up stuff for motor
Spidertrax Off-Road: 9" Rear Axle Housing and Steering Links
Toms Bronco Parts: Power Brake Kit and a new Starter
Bronco Hut and ididit Inc.: Chrome Tilt Steering Column
Hi-Lift Jack Company: Hi-Lift Jack
Deaver Spring: Front Coils and Rear Leafs
James Duff: Rear Quarter Guards and UFO Fender Flares
Painless Wiring: Complete wiring harness
Crawlertech: Crane Hi Clearance Knuckles and Assemble Front Axle
Off Road Design: Doubler Kit for 203/205
Front Range Custom Coatings: Custom Coating
D&K Engines and Machine Shop: Machine Work/Engine Rebuild
Austin Automotive: Engine Rebuild
Randy's Ring & Pinion: Yukon Axle Shafts and Lockers
Hellwig Products: Front and Rear Sway Bars
Magnaflow Exhaust Products: Mufflers
PSC Performance Steering Components: Power Steering Pump, Hoses and Steering Box
Bestop: Bronco Soft Top
Predator 4 Wheel Drive: Assemble Rear Axle
Tomken Machine: Front Winch Bumper
Nick's Trix: Some Bronco Goodies
Odyssey Battery: PC1500 Odyssey Battery
KC HiLiTES: 130w Black Daylighters
TrueHi9: Hi Pinion 9" Third Member
Ballistic Fabrication: Ford 9" Semi-Float Axle Flanges
Red Line Powder Coating, Inc.: Sand Blasting and some Powder Coating
Colorado Performance: Installation of Painless Wiring Harness
Rock Ware: Steering Links
Complete Off Road: Dana 44 Warn Premium Locking Hubs
Bulldog Winch: Bulldog Winch Rigging Kit
4 Wheel Parts: 37x12.5x17 Pro Comp Xtreme Mud Terrain
Addicted Off Road: Rock Sliders
Power Tank: 10lb Power Tank System
West Coast Broncos: Extreme Duty Motor Mounts and Power Steering Brackets
Wild Horses Four Wheel Drive:Brake Lines and Hoses
B.C. Broncos: 5.5" Front Coil Springs
Don Allison: np203 Transfer Case and Some Great Bronco Wisdom!
Dave (ManTruck:) Windshield and Install
Ridge Runners: Hood
Rancho Suspension: Shocks
Four To Go 4x4: Exhaust and Recovery Strap
(ORO) Off Road Only: LiteSPOTs LED Rock Lights
M.O.R.E. Mountain Off-Road Enterprises: Body Lift
Ron Davis Radiators: Aluminum Radiator
The Streetrod Manufacturing Co., Inc.: Rear Disk Brake Setup
Elite Audio Solutions: Complete High End Sound System
Bronco Connection: Weatherstripping
MSD Ignition: Distributor and Wires
Gregs 4WD Xtreme: C/B Radio and Antenna
Twizted Engineering: Front Brake Setup
4WD Factory: Front 4.56 Gears and install kit
Bushwacker: Cut Out Fender Flares
Copperhead Fabrication: 203/205 Doubler Truss Bracket
4WD 4Wheel Wheel Drive Hardware: Grant Steering Wheel
Bronco Design: Roadster Door Inserts
Stage 8 Locking Fasteners: Locking Header Bolts and X Lock locking spindle nuts
Mac's Custom Tie Downs: Custom Tie Downs to keep it safe on the trailer while traveling around
NAPA Auto: Rebuild Kit for NP205
Off Road LTD: Master Craft Harnesses
JB Custom Fabrication: Custom Shifter Knobs for the Triple Stick
Moab 4x4 Outpost: M4O Half Doors
RJM Injection Tech: EFI Harness
Bronco Graveyard: H4 Headlights, Harness and Bezels, Tail Lights and Bezels, Windshield Washer Setup, Wiper Arms and Wipers, Bronco Emblems.
Dakota Digitaland Brady's Garden Center: Bronco Digital Gauge
If you would like to donate to our build please contact me. We have a great list of parts but we are still in need of a few items to complete the build.
J
jwtrapper
Van Lear, Kentucky
A quick update on The Bronco.
It is still at Nemesis Ind. getting the cage and dash built. It should be done this Friday or Saturday. Then its off to TnT Customs for some suspension work. Things have been slow the last few months but I am hoping things will start picking up soon and things will come together quicker.
Cracker: I will have to figure out when I can make it your way to pick up the hood. I was hoping to have it put on before it left Nemesis but they are not going to have time to do it.
Hank_
Dusty
Nice looking skid. I used Poison Spyder parts on my jeep. Perhaps you should expand your line and start making Bronco parts;D.
Henry
J
jwtrapper
Van Lear, Kentucky
We picked up The Bronco and took it north to TnT Customs for some suspension work. The cage still needs some finishing touches so we pulled it out and it is getting finished up while its at TnT. The pictures are not the best since I forgot my camera and I had to use my phone, the pictures do not do it any justice. The cage is awesome. The dash is built into the cage. On the left there will be rocker switches just to the right of that is where the steering column comes through and then the switches for the Headlights and stuff. In the middle section will be the Dakota Digital gauge by its self. Then in the far right part will be some switches for the blower, defrost and vent and a Tuffy Security glove box.
In the back of the cage is a mount for the Power Tank, Fire Extinguisher and First Aid Kit. The seats mount into the cage and are adjustable, they still need to put in a crossbar for the seatbelts also. The Tuffy Security Console will sit between the seats also mounted to the cage. The defrost and vents are ran through the cage also.
Piedmont, OK
Wow! That is amazing. Truly a one-of-a-kind Bronco. The cage is sick. I can't believe we have almost a year and a half to wait to see who wins this thing.
Hank_
Wow!!! Awsome work guys. I cant wait to see that bad boy when it is done. I will be picking up some tickets.
Henry
