Ultimate Raffle Bronco!!
ManTruck
It looks like your not quite ready for the windshield. I will be around for a while and if your ready let me know or drop me a line or buzz me if you have a time frame which works.
Looks really nice and the cage/dash work sets a standard to meet.
Dave
J
jwtrapper
Van Lear, Kentucky
Dash
Power tank, fire extinguisher, and first aid kit mounts.
Tito
CB Fire Starter
Bakersfield, CA
Holy Crap!!! That cage is incredible, what a business card thats going to be. WOW
Wish they would keep the stock cluster in there and not use the Dakota Digital, just put the lit overlay on it. Looks great with the original cluster.
Is that going to fit under a hard top?
Ohio Bronco 21
Cleveland
Way too Cool. That cage alone is worth the price of a ticket. Man oh man would i like to win that thing. Excellent fabrication, Keep it up.
J
jwtrapper
Van Lear, Kentucky
It does look very good with the stock gauge cluster. The Dakota Digital gauge was donated so it will go in, what the winner decides to do with it is up to them. We will hold on to the original just incase.
J
jwtrapper
Van Lear, Kentucky
Looking good! When do you anticipate getting it back? When do you want the hood and ecu?
We should be getting it back down here in about a month, I hope. Then we will come get the hood and ecu from you, or I will see if we can set something up before that. We were going to have Nemesis set up the hood with some struts but not sure if they are going to do that. They have a lot donated in the cage alone.
J
jwtrapper
Van Lear, Kentucky
It fits under the new Bestop Soft Top.
cracker
Pueblo, Colorado
Don't forget, I have the hood and ALL of the mounting hardware for it including the gas struts...
BTW, if you get this soon, I am running Liberty tomorrow (Sunday, 9/19), around 2pm if you or anyone is interested....
J
jwtrapper
Van Lear, Kentucky
Okay I didn't know you had the struts too, that works out great then. We will get it put on as soon as we get it back.
J
jwtrapper
Van Lear, Kentucky
This is going to be the 2011 Raffle Vehicle Tickets won't be available untill Jan. 2011
The 2010 Raffle Vehicle is a 1998 Jeep Cherokee w/5.5" TnT lift on 33's with lots of goodies. Tickets should be ready for it soon.
Our Donations So Far:
T&T Customs: Special Treat
Warn: Warn Winch
Tuffy Security: Security glove box and center console
Ruff Stuff: $250 worth of Parts
Seal Brothers: Paint Job
SSR Auto: Paint and supplies
Canon Tuck: 205 transfer case
Nemesis Industries: Cage, Custom Dash and some special touches
Battlement Fabrication: Rear Bumper and Tire Carrier
PRP Seats: Two of their Daily Driver bucket seats
Premier Power Welder: On Board Welder
Poison Spyder Customs: Rear Gas Tank Skid Plate
Craig Fire and Safety: First Aid Kit and Fire Extinguisher
Royal Purple: All Fluids
O'Reilly's Auto Parts: Dress up stuff for motor
Spidertrax Off-Road: 9" Rear Axle Housing and Steering Links
Toms Bronco Parts: Power Brake Kit and a new Starter
Bronco Hut and ididit Inc.: Chrome Tilt Steering Column
Hi-Lift Jack Company: Hi-Lift Jack
Deaver Spring: Front Coils and Rear Leafs
James Duff: Rear Quarter Guards and UFO Fender Flares
Painless Wiring: Complete wiring harness
Crawlertech: Crane Hi Clearance Knuckles and Assemble Front Axle
Off Road Design: Doubler Kit for 203/205
Front Range Custom Coatings: Custom Coating
D&K Engines and Machine Shop: Machine Work/Engine Rebuild
Austin Automotive: Engine Rebuild
Randy's Ring & Pinion: Yukon Axle Shafts and Lockers
Hellwig Products: Front and Rear Sway Bars
Magnaflow Exhaust Products: Mufflers
PSC Performance Steering Components: Power Steering Pump, Hoses and Steering Box
Bestop: Bronco Soft Top
Predator 4 Wheel Drive: Assemble Rear Axle
Tomken Machine: Front Winch Bumper
Nick's Trix: Some Bronco Goodies
Odyssey Battery: PC1500 Odyssey Battery
KC HiLiTES: 130w Black Daylighters
TrueHi9: Hi Pinion 9" Third Member
Ballistic Fabrication: Ford 9" Semi-Float Axle Flanges
Red Line Powder Coating, Inc.: Sand Blasting and some Powder Coating
Colorado Performance: Installation of Painless Wiring Harness
Rock Ware: Steering Links
Complete Off Road: Dana 44 Warn Premium Locking Hubs
Bulldog Winch: Bulldog Winch Rigging Kit
4 Wheel Parts: 37x12.5x17 Pro Comp Xtreme Mud Terrain
Addicted Off Road: Rock Sliders
Power Tank: 10lb Power Tank System
West Coast Broncos: Extreme Duty Motor Mounts and Power Steering Brackets
Wild Horses Four Wheel Drive:Brake Lines and Hoses
B.C. Broncos: 5.5" Front Coil Springs
Don Allison: np203 Transfer Case and Some Great Bronco Wisdom!
Dave (ManTruck:) Windshield and Install
Ridge Runners: Hood
Rancho Suspension: Shocks
Four To Go 4x4: Exhaust and Recovery Strap
(ORO) Off Road Only: LiteSPOTs LED Rock Lights
M.O.R.E. Mountain Off-Road Enterprises: Body Lift
Ron Davis Radiators: Aluminum Radiator
The Streetrod Manufacturing Co., Inc.: Rear Disk Brake Setup
Elite Audio Solutions: Complete High End Sound System
Bronco Connection: Weatherstripping
MSD Ignition: Distributor and Wires
Gregs 4WD Xtreme: C/B Radio and Antenna
Twizted Engineering: Front Brake Setup
4WD Factory: Front 4.56 Gears and install kit
Bushwacker: Cut Out Fender Flares
Copperhead Fabrication: 203/205 Doubler Truss Bracket
4WD 4Wheel Wheel Drive Hardware: Grant Steering Wheel
Bronco Design: Roadster Door Inserts
Stage 8 Locking Fasteners: Locking Header Bolts and X Lock locking spindle nuts
Mac's Custom Tie Downs: Custom Tie Downs to keep it safe on the trailer while traveling around
NAPA Auto: Rebuild Kit for NP205
Off Road LTD: RCI Street Belts
JB Custom Fabrication: Custom Shifter Knobs for the Triple Stick
Moab 4x4 Outpost: M4O Half Doors
RJM Injection Tech: EFI Harness
Bronco Graveyard: H4 Headlights, Harness and Bezels, Tail Lights and Bezels, Windshield Washer Setup, Wiper Arms and Wipers, Bronco Emblems.
Dakota Digitaland Brady's Garden Center: Bronco Digital Gauge
Rockstar Kustomz USA: Edelbrock Water Pump
Middick's Locksmith Shop: Lock Work
Columbine Automotive Products: Plug in Heavy Duty Jumper Cables
Daystar: Body Mounts, Bump Stops, Winch & Jack Accessories
If you would like to donate to our build please contact me. We have a great list of parts but we are still in need of a few items to complete the build.
FRANKO289
Bronco enthusiast
DARNNNNN ... THAT CAGE IS SICK !!! no rear seats ?? no hard top ??
J
jwtrapper
Van Lear, Kentucky
No rear seat and no hard top. Everything is donated, PRP donated the front seats but couldn't do the back seat also. It gave Nemesis a lot more freedom to play with the cage not to have a rear seat also. On the hard top, it just didn't fit into what we were trying to build.
kbldawg
Marshall, AR
Wow! That cage is a work of art, very nicely done! I love how they totally integrated it into the Bronco.
Who would even run a top with that cage in there!!?
bptommy
Arlington, TX
The cage is amazing I love it with the original cluster in it, the new cluster will look good to ...;D I just cant get over that thing ive been staring at it for hours...:eek:
