I’m confused - what the heck is it for??Irrelevent.
That is a thermal switch. The 2 ports connect when a specific temperature happens. Ideally unscrew it and put a plug in the hole.
Caps will make it look cleaner, but won't change the function.
Just realized that is in an intake runner. That might be a more weird valve than I was thinking. Remove and plug is best. If there is any vacuum on the ports it needs a removed or caps. A quick loop of vacuum hose between the two would be the really quick fix until you (never) get around to removing it.
Can you get a wider shot please? It’s a very unusual place for any kind of a vacuum port.
And sitting so close to the distributor as it does, in theory it should be a coolant passage, as was originally thought.
Even though Weiand is known for having some unusual variations on their versions of the Ford manifolds, that still It’s a strange set up.
There is another tee with lots of plugs (including bolts stuck in hoses that I may replace with proper caps), and the brake booster hose comes off the top:Where is the brake booster getting its vacuum from?
I just noticed that at the back of the intake, manifold, in an individual runner, there is a plug.
This location is usually for a vacuum manifold, or “vacuum tree“ to connect things like the vacuum booster and other needed accessories.
Yes, I noticed that for the first time when my carb flooded. The nipple on the carb is plugged. I tested the vacuum advance by sucking on the hose and it seems to work, so once I have the carb rebuilt I plan to set timing and then plug that hose back on and see what happens…It also looks like your vacuum advance hose for the distributor is disconnected and just sitting on the intake under the coil. I don't see anything on the ported vacuum on the carb, so it probably just got knocked off and not put back on.
Great. Plenty of vacuum sources then.There is another tee with lots of plugs (including bolts stuck in hoses that I may replace with proper caps), and the brake booster hose comes off the top:
