Unstable?
Yellow75
Sioux Falls, SD
It honestly depends on your shocks and springs. I started with an unknown brand of springs and duff shocks. I have a 3.5" lift and 33's though. Going into corners was dangerous with speed. The nose dipped pretty bad. Went dual shocks up front and It handled MUCH better but was hard on the kidneys!
Now I have the BC 3.5" coils with 1 Duff shock on each corner and it's very stable but a bit rough in the bumps. I'm switching to the Bilstein 5150's as soon as the autozone opens up here.
In short. If it leans bad ( don't think it will at all ) you can always add a shock or a swaybar.
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
The taller you go, the more pronounced every little problem becomes. Worn bushings or balljoints/tie rods or steering box hurt hurt the stability alot. With every thing perfect and with the best shocks money can buy, you still wil need to be extra carefull in panic type situations. Thats just the nature vehicles in general. Sports cars aren't low to the ground just for looks.
HotWheels
Twilight Zone
depends on what u'd like to do with it. if u are mostly street keep it lower is better with MPG and street handling characteristics. i went to a 1 1/2 suspension and a 1 inch body with 33 inch tires. I believe this gives me a great daily drivers and trail vehicle. If you want to drive a pig build a pig. If u want to drive your rig, build YOUR rig. Forget everyone else. Make this fit ur desire. Too little in life does.
8)
velpoe
Cumberland, MD
In a panic situation, lifts are typically not good, unless you like barrel manuevers ;). I have the BC 4.5 lift and like it alot. I had some excess body roll, but then went to dual shocks and it handles very well.
As for gears, it depends on your use and the transmission, auto or manual. You can run it with 3.50's, but you'll want some extra gearing...4.10's or 4.30's would be better, and you would still have decent highway rpms...if you crawl or do alot of wheeling, 4.56 or 4.88's are probably the way to go.
Do lots of research before dumping the $$. I still have 3.50's but am planning on 4.30's with a Detroit electric locker, as soon as I have the $$$$$$.
