Unstable steering
g-71
Just installed a 2.5 suspension lift (progressive rate coils, adjustable track bar) I set the toe in to 3/16. Took it for a test spin and the steering is VERY unhappy ! Feels like it over reacts to the steering wheel, and hitting bumps seems to divert the truck. I expected it not to drive perfectly until I was able to get an alignment, but I did not expect it to be almost undriveable above 40 mph ?
Any help or suggestions would be greatly appreciated.
Thanks in advance,
Mike
bronconut73
Sounds like classic "bump steer" due to too much steering linkage angle.
Dropped pitman arm?
Dropped track bar bracket?
Some 2.5" lifts need those.
Some don't.
All behave better with them though.
And I'll add to what bronconut said by the fact that the "some do and some don't" scenario probably has just as much to do with the individual driver as it does to the overall vehicle setup.
I'm running the same setup (by choice) for now while I experiment to be able to give a better recommendation to people here. I've always had lifted Broncos, but have also ALWAYS used the steering drop components once I got above 1.75" of lift. In a daily-driver, not correcting the angles was unacceptable to me.
So I totally agree with the recommendation to add the drops. But first tell us more detail of what it's doing and how the rest of your rig is set up. I drive my '68 with the same setup, and while I find it finicky on the road, it's certainly not unsafe.
But I've been driving Broncos regularly for 41 years now, so if you have not driven older trucks and utility vehicles before, there could also be a perception difference to account for in our discussions.
Lots of things can make one of our rigs drive like crap though. Here's a basic list:
1. Steering box not on-center. For any lift you MUST have an adjustable draglink. It's the only reasonable way to bring the steering box back to center. This position is very important.
2. Non-Stock steering linkage that's not matched to the other stuff.
3. Tire pressures.
4. Tire type and size.
5. Tire condition.
6. Wheel specs and how they relate to the truck and the tires used.
7. Rear components being loose
8. Playing with your toe-in settings. Small effect maybe, but distinct. Your 3/16 is a good start though.
What else was done to the rig? Either by you or the PO?
The bottom line though is that with even just 2.5" of lift your Bronco will be a bit willowy/wallowy on bumps and corners. During braking and accelerating.
But it's almost all fixable without much drama.
Let us know more about your rig and the other things mentioned.
Thanks. Good luck.
B RON CO
Statesville, NC
Hi, X2. Did you get all new front end bushings? Even if you got 7 or ? degree caster bushings (i would), changing from rubber to poly will give a completely different feel. More castor should "stabilize" straight forward driving. If you could post some pics of your front end you will get better advice. By 3/16 toe in you mean the front of the tire measurement is 3/16 smaller then the rear of the tire measurement. Good luck
sykanr0ng
Power steering or manual?
If power go to 7 degree C bushings.
Do you have an old school alignment shop near you?
Most modern shops do not know how to do the alignment on a Bronco or Ford truck of that era, they will tell you it can't be adjusted rather than admit they don't know how.
Pics of your steering from the front would help.
Is your track bar and drag link parallel?
G
g-71
Thanks for the replies, here is a little more detail. All new ball joints, bearings, etc about 1500 miles ago when I did the front disc swap. Factory manual steering, the truck drove real well. What it has now, as stated 2.5 sups lift, adjustable track bar (11 5/8" from frame to backside of wheel, measured just in front of the coil spring both sides equal) new cooper stt pro tires, new AR aluminum wheels, toe in 62 1/4" in front, 62 7/16" measured at the back of the tire. New 2 degree, polyurethane C bushing, I did get a chance to get it down to the freeway, got her up to about 65, wondered a bit (expected since I haven't had it aligned yet) it just seems to be real bad on the bumpy rural roads. I will try to post pictures as soon as I figure out how to.
Thanks again,
Mike
Skiddy
I would play with your tire pressure, amazing how it can change it
Double check your toe. Put two pieces of tape on the tires (one on each) at the front of the tires. Measure the toe at those tape marks. Roll the truck back and measure again from behind. Do both just below the radius arms so you can pull the tape measure tight.
Just hooking a tape measure on the tire is not accurate. The tread blocks are not identical. The shapes vary a lot and if you just hooked the tape on the tread I am sure you have the toe wrong.
And you don't have enough caster as well.
blubuckaroo
Grease Monkey
Ridgefield WA
I see a lot of recommendations for adding caster by swapping "C" bushings. One of our vendors has even gone all the way to including seven degree "C" bushing with their minimal 2.5" lift kits.
I don't know if I'm all alone again, but I've got to disagree that this is the appropriate fix for wandering issues. Certainly more caster will make a vehicle with geometry issues run straight, but there is a big downside to this band-aid remedy.
Too much pinion angle, and you'll have a problem with your U-Joints, driving in 2WD with the hubs locked.
I'd suggest you check your pinion angle before trying to fix your wandering problem this way.
Some owners in perfect climates may not see the need to ever drive in 2WD with the hubs locked, but that's how we drive here in the winter. That way when thing get slick with snow and ice, you don't have to get out every time you need to shift in and out of 4WD.
Certainly you can do whatever you want to straighten up your car's issues, but you should consider the downsides as well.
G
g-71
Quick update, took out the 2 degree C bushings, installed the 7 degree bushings that came with the kit. The front end of my truck is much happier, the bump steer is gone, and he wandering is WAY better. My question is 7 degrees too much ? Should I order the 4 degree bushings? Is it possible to have too much caster ? Thanks for all the replies and opinions, I really do apreciate all feedback !
blubuckaroo
Grease Monkey
Ridgefield WA
You can read my previous post. Or better yet get yourself a magnetic protractor and see if your driveline can afford a seven degree "C" bushing.
http://www.4xshaft.com/driveline101.html
It is possible to have too much caster, but it is really difficult to achieve in a Bronco.
Modern caster specs are typically around 5-7°, stock Bronco is typically around 0°. If you put 7° bushing in and lower a bronco that happens to have a better than average factory caster numbers, you might get a little too much caster.
