Unstable voltage Problem
Fitz24
Trying to figure out why voltage measurements inside the cab are less than at the battery.
Digital voltage meeting in cab is wired off a direct line from battery. It is turned on and off through a relay connected to a 12 volt switched power source.
Battery voltage with DMM shows 12.5 volts. Inside voltage meter reads 11.5 volts. As I turn on radio, AC etc. the voltage drops more.
Shouldn't it stay more stable near 12 volts? Running a 3G setup.
What ground points are you measuring to?
Measure the voltage between different grounds while loaded. The battery negative post to alternator case, to the dash, etc.
With the alternator working right you should see closer to 14V, not 12
Are you measuring at the battery with a hand-held meter and in the cab with the in-dash gauge? Maybe the two read differently themselves? If you have not then, I would measure the voltage as close to the gauge as possible with the same meter you're using at the battery.
And yes, you should have nearer 14.5v when the engine is running and it should remain "mostly" stable while the engine is running even as you turn on accessories.
Without the engine running though, you will definitely see a drop. If that test was with the engine running, then as said your charging system is not working.
Is that relay just for the gauge? No need to add the complexity for a simple gauge that uses almost zero current. Just run it from the ignition switch or an accessory. Even running it off of the input connector for the IVR is good if the gauge is in the stock cluster. Very convenient.
Steve83
Because the resistance in that circuit is substantial, compared to the amount of current flowing through it. The result is a "voltage divider circuit". As the current changes, so does the division of the (source) voltage.
To help you fix it, we need to see LOTS of pics of the entire circuit: beginning at the battery (-) post, through the clamp into the big black wire to the block/frame/body (ground) to the return wire for your gauge, out the hot wire, to the relay (I guess), through its hot wire to (hopefully) a fuse, and the rest of the way back to the battery (+) post. Try to get pics that show EACH connection along that path.
The first several posts in this thread explain how to embed them in your posts here:
http://www.supermotors.net/forums/thid-5972-how-do-i-post-pictures-sounds-and-or-videos
Fitz24
Fitz24
Going to do a test comp of DMM vs Guage tomorrow. Bronco has been sitting about 6 months while installing 4r70w so battery needed a good charge. After charging battery, guage inside stayed contsant at 13.9v. At the battery got a reading of 14v wth DMM.
I need to check my ground connections from B to Frame to block. I don't remember seeing a ground to the frame, just to the block and body.
Relay provides a key on power to activate a accessory power fuse panel inside the cab.
Fitz24
Fitz24
Measured voltage from battery + to battery -, alternator case, and body. Same reading at each point. After putting a good charge on the battery, readings were 13.9v inside on gauge and 14v at the battery (to all 3 points).
Well at least a .1v difference to the inside gauge is not out of line. And can still give you usable data as you're driving.
But it still wouldn't hurt to check, just to see if that 1/10th of a volt is between the different gauges, or due to the wiring distance.
Would be consistent with the wiring, but still curious.
Fitz24
Fitz24
Same measurements inside when comparing DMM reading to volt meter. So, readings staying in the 13.5 to 13.9 volts now, even when turning accessories on. Could the issue have just been a week battery that needed a good charge? Battery is a 2 year old yellow top.
