***UPDATE***
Well, Stout22 and I worked most of the day on trying to get this corrected. We took the whole front end out of the Bronco leaving the radius arms bolted up to the axle. As you might suspect, we found our problem as the passenger side radius arm was resting about 1.5 inches lower than the drivers side radius arm. So, we took it all apart double checking the C bushing orientation etc. Everything was put in correctly the first time. We cleaned the c-caps and the axle wedges off real well and put dish soap all over them. Then we put dish soap on all of the c bushings. We put it all back together and wouldn't you know same results. 1.5 inch difference from passenger to drivers side. So, we took it apart and put it back together for the next two and a half hours yielding the same results. We even swapped radius arms from side to side, swapped c caps from side to side, swapped c bushings from side to side etc. Nothing worked. The results were consistent every time. 1.5 inch difference from passenger to drivers side. We even measured the axle wedges to make sure they were the exact same distance from the ground and they were. So was the axle tube. We lined up the radius arms next to each other as well to make sure they were not deformed in any way. It's very strange because the truck sat completely level with the original suspension on it. So after working on it for 7 hours, we put it all back together. It leans just like it did before we took it all apart.
My new tires will be here this week which makes matters worse. It's not real exciting driving around with a Bronco all leaned over to one side. It was suggested that I bend one of the radius arms to offset that 1.5 inch difference and call it good. At this point I'm willing to do anything.
