UPDATE on caster alignment
Casey835
I've been making good use of the search function feature and think I got half ass understanding, now I would like to get a ill collective input. I have the JD 5.5 monster 4link lift which I believe comes with 6.25 c bushings.
So with these numbers, I don't think 7 degree bushings are gonna help. I think a cut and rotation is in my very near future. I was planning on adding the 8 degrees and using the 2degree bushings which seems to be a popular decision for most who do this. I think it will be a fun project. Any help or direction on setting pinion angle and knowing how much to turn the Cs would b greatly appreciated. If I need to add any info or pics please let me know. I haven't exactly wrapped my head round how to incorporate the alignment specs with what needs to be done.
Yes I know I need to adjust camber, I have the shims.
DuctTape
Bozeman, MT
I thought I read somewhere that factory caster was 1.5 degrees?
More importantly, how does it feel going down the road?
Casey835
Casey835
It was bad with manual steering even worse with power steering. It is very unpredictable and has that dartyness about it that makes it scary to drive. With manual steering, even though it was bad, I would have driven it anywhere. Don't care to drive it out the yard with power steer.
Got any pictures of your setup? Those specs alone don't indicate 100% why you have the dartiness and other oddball handling traits that make it feel so strange.
Is this an Early Bronco? The specs shown there are for an '83 Ranger, so you'll see some serious discrepancies from what is expected.
Your camber numbers look great for an EB.
Your caster numbers look low for what you have, but I know from experience that with those caster numbers your truck is safe to drive. Putting more in will help I'm sure, but it's possible that it would just be masking another issue or three.
Your toe-in I'm not sure about. What is the spec for a Bronco again? We were just talking about it, but I still remember it in inches, haven't memorized the degrees yet.
So, basically what tires are you running with your 5.5" of lift, and what condition are they in?
What wheel size with what backspacing or offset?
What shocks and how many?
What design steering linkage, with what modifications for the lift, and what condition are the components in?
Who installed your 4-link and are you sure it's all set up correctly?
Just a few things to talk about some more. ;D
And some detailed pics of the front steering linkage and 4-link setup would be great.
Looking at it again, the toe-in seems excessive for larger tires maybe? You might want to do a few quick tests by decreasing the toe-angle and increasing it. Just to see if you see any improvement.
Basically, along with those normal alignment things, your steering linkage has to be like Mary Poppins. "Practically Perfect In Every Way" ;D Your tires can't be too worn or too radical (or worst of all, both!) or too damaged. And if your wheels are wider and heavy in the negative-offset department, every little problem will be magnified.
Air pressures, tread wear, differences between tires, loose or damaged components (cracked frames come to mind), lockers such as Detroits (especially the Nascar sell-offs), softer shock setups, other limiting factors like parking brake cables and brake hoses, and driveshaft lengths, and any one of dozens of other issues could be creating or adding to your darting Bronco.
Casey835
Casey835
Alignment
No lockers and as you can see everything is new. I will get more answers as soon as I get a chance to post more. 35" boggers
Looks great Casey. Nicely turned out.
And I hate to say it, because I doubt that many other people bother either, but with that much lift I would be tempted to add a dropped pitman arm and a dropped trackbar bracket to the mix. Even though you're running a riser and a TRO.
It's just because at that height, those angles are getting back up into the semi-steep range that would not be present with a 3.5" lift and your setup.
But, there are a lot of other EB's running around with what you have and not that bad on the road. Hmm, or are they?
Maybe they are just trail rigs? Or maybe they just don't get out that much, or the owner doesn't really care how badly it does on the road, as long as it's good off the road. I don't know, but it's possible.
Still, if it was mine, I would try to get those angles down just a bit more anyway. And if you can, find someone who's tires and wheels you can borrow from a rig that drives well. Boggers aren't exactly the most road-friendly tire out there. Especially if their well used. Are your tires new too?
Casey835
Casey835
Alignment
New tires 35x14.50-15
If put drop pitman then I'm gonna get bad bump steer or the pulling to either side, right? They are almost perfectly parallel -trackbar/drag link.
Casey835
Casey835
It may be nothing but I don't like how this saddle will rotate when steering wheel is turned in either direction
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
Not enough caster. Shoot for something in the range of 5-8* with a 35 inch tall tire.
If your tie rod and drag link are at the same angle, and provided your axle is centered, there is no reason to put a drop bracket on either.
The only thing that does is lower your roll center on the axle and flatten out the axle shift during travel. What that means is drop trackbar brackets on the frame side will make your Bronco lean a little more, but have the axle shift less in suspension flex because the arc of track bar is flatter.
I would check out tires, and look to adjust the caster between the knuckles after correcting the general caster. You have a difference of about half a degree side to side, which will cause it to track the direction with the least amount of caster.
Casey835
Casey835
look to adjust the caster between the knuckles after correcting the general caster. [/QUOTE]
Not sure I follow here.
Crawdad
If you are going to Meet n Greet next weekend talk to Charles. He knows a good bit about caster angles and stuff. He has one of those fancy tool thingies to help dial it in.
surfer-b
What Donk said, even if you get the caster set between 7-8* you will still have some bumpsteer with the angles of the drag link and tracbar in those pics. When the susp compresses it will shift the axle to the pass side causing bump steer. The flatter, or I should say the more parallel to the front axle, those 2 are the better. With that said the caster is what you want to address for the front end wander, along with toe-in, and the flatter drag and tracbar will just make it better to drive.
Casey835
Casey835
It's not that I'm wishing a caster issue or anything, as I stated earlier I have read countless threads of poor caster characteristics and it seems that's what I have in common with them. I don't seem to have the bump steer issue but maybe I don't quite understand bump steer. I thought characteristics of bump steer was hitting a bump and it pulling to one side or the other.
If memory serves me I can't run a drop track bracket due to my tro setup. It is a BC tro setup.
If your tie-rod and trackbar bracket are lined up in the same plane, then you're right. You won't be able to run a drop bracket due to interference issues. But look at them before deciding, since there are Broncos where this doesn't seem to be an issue, and others where it is indeed an issue.
From here, it looks like there's some room to drop even if they are in the same plane. Here though, it would depend on how much upward travel your suspension is capable of. Looks like a pretty flexy setup, so it might be able to get up that high. If not though, you can drop.
In answer to your question in post #8, yes, if you only install a dropped pitman arm and not a trackbar bracket, you will put your linkage in a situation where bumpsteer is a distinct possibility. There are very few instances where you drop one without the other. Parallel is usually your friend.
Saddle rotation is definitely a problem too. With spherical rod ends you have a joint that's easier to rotate by design. Add improper geometry to your equation and you get tie-rod rotation. Any rotational movement usually means you get a more vague steering feel and resulting control.
Can you shoot another pic from the side, looking over the driver's side tire? What you want to see is the least amount of front-to-back angle between the rod end at the pitman arm and the rod end mounting point (saddle) of the draglink.
That angle is important even with standard rod-ends. Just more so with spherical rod-ends ("Heim joints") because of their willingness to rotate.
Sometimes the fix is as simple as rotating the saddle angle rearward or forward to improve the geometry. If you've ever looked at a stock Ford link, the mounting saddle is rotated at an approximately 45° angle so the draglink mounts with it's grease fitting pointing up basically at the front bumper.
That's not always the cure with your type of linkage, but noting where the lower end is in relation to the upper end when steering can at least highlight an issue if it exists.
Worth a look anyway.
Your wheels obviously have minimal backspacing, and with that tire size, I assume they're at least 10" wide? Or maybe even 12's? With this combination, EVERYTHING is going to be magnified and enhanced, so any little minor looseness in the wheel bearings, any vagueness in the steering feedback (the rotating saddle) any extra flex in the system (I see spacers under the box?), not enough caster for the situation, and you're going to have some funky road handling characteristics for sure.
Every time you dial in one problem though, you're just one step closer to getting it back to a reasonable driver. However, if you did not have those tires on before, when it drove better, then I doubt you'll ever get it back to where you like it. The tire and wheel combination alone are not exactly the perfect setup for the street. Not saying it can't be done. Just saying it's going to be a lot more work on your part to bring it back to snuff.
Heck, even nice steering links like you have probably flex more than you can imagine just due to the width and offset of the tires and wheels.
And why the spacers on the steering box? Just curious.
Good luck.
Oh, and back even farther to your original question (I think?), rotating the knuckles is pretty straightforward. A bit of a hassle, cutting through all that weld of course, but at least it's pretty basic work with a cutter, an angle finder of some design, and then a welder.
Depending on your current driveshaft angle, you might consider going down to a 2° offset poly C-bushing first, then factor all your yoke rotation from there.
The lower degree bushings don't help the caster at all, they're strictly for making the drive pinion and u-joint/driveshaft angles more natural. Then you adjust ALL of your caster with the steering yoke rotation.
There are at least a couple of very good tech writeups about that process hereabouts. Don't have a link to them, but maybe someone can help you out there. Maybe there's even one in the Tech Article section? Might be worth a look, if you haven't tried that already.
Casey835
Casey835
No spacers under steering box. There is a reinforcement plate between frame and box. I have considered a different tie rod setup to get rid of rotation of that saddle. Those tires have been on it since before rebuild completion. Only thing different is change from manual box to power. Then that's when it got crazy, and angle actually got better, but I also read when going to powersteering more caster is needed than manual. I guess you may be seeing an extra nut on bottom of pitman arm. Just like a jam nut-prolly not necessary. I am going to play round with few different things and see what I can do, but I think I still need more caster. I'm tring to make sure I rotate it enough and not to much. So I guess my question is would I rotate the Cs 8 degrees from where they sit now or point pinion toward case better then rotate needed degree from there... Which would be a few degrees more or does my cbushings take care of that?
Casey835
Casey835
I have thought bought doing the mock up with the 2degree bushings and setting pinion then figure degree of rotation. I've read several of the threads on all this and looking for more to get as much as I can. I did look in the tech but got sidetracked before completion...I'll check that again. I do appreciate everything. I'm gonna call or email BC to see if they can offer any advice on their rotating saddle. None of this is a burden to me. I take it as a learning of how to make things work and is how I enjoy my time off work and a way to spend my money when not working. And again thank you!
Casey835
Casey835
Alignment
Something else I noticed and wanted to mention is the coil springs bulked forward right off the top of the perch then angle back toward top at the spring bucket. I'm thinking because the caster is not enough and the axle housing is rotated forward.
Maybe in those last two pics you can see the little rotation in that saddle.
...Those tires have been on it since before rebuild completion. Only thing different is change from manual box to power. Then that's when it got crazy...
Hmmm, I wonder if the steering box could be off-center? Did you verify that it was perfectly centered before putting the pitman arm on by any chance?
I know that's basic, but maybe it could have been moved off of center before you set things up and you didn't know it.
At this point, it's such a simple check, you might consider just doing it anyway.
...I also read when going to powersteering more caster is needed than manual.
Not necessarily "needed" so much as more caster is much more tolerable with power assist. The more positive caster, the harder it is to steer.
With manual steering and narrow tires and wheels, mine drove very well at only 1 degree or so of positive caster.
Now that I'm going power (finally!) I'm going to shoot for 4 to 6 degrees. But with my tire and wheel choices, I'm betting that 4 would be plenty for me.
Point the pinion first. That's why I mentioned going back to a 2 degree offset bushing, then getting all of your caster correction from the rotation of the yokes.
Leave the c bushing mounting pads where they are on the axle tubes as well. You're only concerned with the outer steering yokes, or "C's", to take care of caster.
So base it on your current settings, minus the 4.25° you lose when going to a smaller C-bushing, plus whatever you want from the rotation of the yokes.
In other words, you set your pinion angle with the bushings, and you set your caster with the yokes. That's all they're doing
But that's all just conjecture at the moment. Until you take a closer look at your pinion angle you won't know how much to change. I'm just guessing you'll want to go down to 2 degrees in the bushings, but you can verify that first.
One other thing I can think of that is effected by the c-bushings is the trackbar's lower mount. Whenever you pivot the axle housing, whether by lifting or lowering the suspension, or through c-bushing choice, you necessarily change the angle of the lower trackbar stud/bolt.
This can be a good thing, a bad thing, or neutral. Depends on how it aligns with your upper mount, or how your bar is set up. In your case, since you have a rod end at each end of the trackbar (is that correct?) then it may not matter.
But it's something else to take into account.
