- Nov 3, 2003
- 49,351
so this upgrade would probably not be worth it for mild use? I understand hard core stuff, but mild trails?
The way I see it, it's not just about trails or off-roading. You can heap just as much or more abuse on a differential on the street where you have oodles of traction as you can on the trails.
To me it's about the tire size vs gear ratio, or the gear ratio itself, or the engine torque. Or ultimately it's about the users right foot!
The dilemma with many 44 users is the lower gearing. A 4.11 is just flat out stronger than a 4.88 in a Dana axle. The pinion gear gets smaller and smaller as the numbers increase.
So going in the proper direction gear ratio wise puts your differential at a bigger and bigger disadvantage.
Basically it's all about a balance in the Force.
You have to look not only at your use, but at your tire size and gear ratio.
What's yours going to be?
