Upper idler pulley on explorer front dress??
NJBronco
I got all new pulleys and an ac delete pulley. Everything went on but the upper idler on the ac side. I seem to only have a little rubber bushing, bolt and a washer that threads into the bolt. But the ac side bracket doesn't have a cast sleeve for the bearing. I'm wondering if I'm missing a mental sleeve or does the washers just crush the inner bearing race? It's off a 2000 explorer 5.0
It's come up recently that there are two completely different designs that Ford use on the Explorer idler. Different attaching methods at least, but same diameter pulley.
Is yours the type with the small lip, or is it smooth all the way out to it's curved edge?
And is the type you got as a replacement the same as the type you took off in that regard?
N
NJBronco
Smooth type and it's the same as what came off. Alignment spacing seems fine but I do t under stand why the lower pulley mount had the nice cast bushing that fits the bearing and the upper does not
Not sure about that one either. Hopefully someone has the straight scoop for you.
Hmm, maybe it was just the wrong part in the box?
Seems like it could happen.
N
NJBronco
It matches my old pulley perfect. I can't seem to find anything on google that shows that upper pulley being installed. I may have to head to the junkyard and pull off a pulley to see if there's any bushings. Alignments fine but the bolts like have the diameter of the bearing hole. So I feel like I must have lost something
N
NJBronco
Someone must have an explorer setup that they can pop off the upper pulley to see what hardware goes on the bolt.
PNW
My upper pulley had a funky little rubber 0-ring that centered the bolt that goes thru the inner race of the brg and holds it tight.
I've gone to a different pulley there now...
Desert Dweller
Central WA
The one I just took apart had what looked like a metal star washer that threaded onto the bolt..It slipped into the idler pulley to center it on the bolt (about 1/8" thick). Then there was another star washer looking thing that screwed onto the bolt and snugged up against the race of the idler bearing. Was very solid and centered the idler nicely. Then the whole assembly was torqued onto the bracket. If the outside (larger) star would be left off, then the idler would not be centered...:cool:
PNW
Or you could have the Desert Dweller turn you a nice fitting collar that centers the bolt inside the inner race and that centers it! Thanks again... : )
Viperwolf1
electron whisperer
Here are the 2 versions of the bolt.
N
NJBronco
I have the bolt on the left. I guess if it fails I'll source the one on the right. Thanks for all the clarification guys. She's one and seems good for now
