V Belt help
BroncoBub
Anyone who installed a vintage air system have a part # for the v-belt ac?
blubuckaroo
Grease Monkey
Ridgefield WA
Even Vintage Air couldn't answer that question for me.
I had to tie a piece of rope around the pulleys, and took it to the parts store. to measure it. Mine has a Gates 9570 belt.
My Vintage Air kit is the one with the compressor on the passenger side and a three groove crank pulley.
BroncoBub
BroncoBub
I noticed they didn’t have an answer for the v belt size. I have the driver side mount compressor with dual groove pulley. I found a thread on here that I believe BcBroncos uses a 15545 belt. I’m going to try and locate one local.
B RON CO
Statesville, NC
Hi, set the adjustable accessory, probably the alternator, so it is close to the block and slip a string around all the pulleys like blubuckaroo said. Any auto parts store will have the correct length and width belt. My guess ii the part number is the wrong belt. Good luck
BroncoBub
BroncoBub
Yep thats my next step. Thanks
BroncoBub
BroncoBub
Got my v belt installed. I could go a little smaller but, this seems a good fit.
I also got that GTO upper radiator hose and tested it with the straight up water outlet. Seems fine and I shouldn't have any issues with the other hoses. I gave part #'s in the pictures. Oreilly's had the upper hose and autozone had the belt.
Now I can take everything apart and prep it all for paint.
Bub
