Vacuum brake booster question
jckkys
It doesn't pull the peddle down. It helps your foot push it down. If there is significant movement you may have air trapped in the system requiring bleeding to remove it.
jckkys
I'll try to walk you through. The brake system is hydraulic, not vacuum. Air in the hydraulic brake fluid needs to be bled from the system. I can't dumb it down any further. I can suggest reading a basic auto mechanics book I'm sure they have pictures.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
No shit. He's asking about the booster. Not the hydraulic lines.
sp71eb
North Liberty, Ia
Is the booster new or did this just start happening with a booster that was in the truck? I have seen bad boosters before but not one that will pull the pedal down without assistance. More info please.
jckkys
There is a direct mechanical linkage from the brake peddle to the master cylinder. The booster only assists the input effort made by the driver's foot. It doesn't pull the peddle. Air in the brake lines compresses so with the assist of the booster it compresses a lot more. Liquid doesn't compress so the peddle won't move farther when intake vacuum is introduced after the engine is started. With properly adjusted brakes the peddle movement likely is caused by air in the brake fluid. The op assumed the peddle movement is a result of the booster. The booster only magnifies the movement. I can't put the concept in simpler terms.
AZ73
+1 exactly
Jeff76
Alpharetta GA
This is one of those 'drown me in the shallow water' topics, so I won't pretend to know the answer. But I've owned one of my broncos (76) since new, and I can unequivocally say that if you put your foot on a hard pedal, start the motor, the pedal will compress further. This is a fact, and I think it's related to the atmospheric booster, but I don't think it necessarily is indicatve of of brake problem, or improperly bled brake lines.
Jeff
broncoitis
Hmmmmm! This could get interesting. ;D Gonna stay neutral hear but I have experienced what has been mentioned. This could very well be because of the lack of vacuum on the booster when the engine is not running the pedal will come up a bit. With vacuum reapplied from the running engine the pedal will come down a very small amount.
I know this is about the Vacuum Booster, but it don't think my Hydroboost Brakes do that at all!
Apogee
Tangent, OR
Even with properly adjusted brakes, the pedal will always have movement as there is always "slack" in the system even if there is zero air. The piston seals retract the caliper pistons slightly so that the pads don't drag excessively, there is generally .015" to .025" clearance between the pushrod and MC, there is slop in the mechanical pedal pivots and possibly most importantly is that there is a certain distance that the pistons and seals must travel in the MC before they cover the reservoir return/compensator ports. Assuming a rather typical 4:1 pedal ratio with a vacuum assist application, this means that you will usually have at least 1/2-1 inch of pedal movement before any significant pressure is generated by the system, with or without a booster.
As stated above, the vacuum just assists the effort of the driver when the brakes are applied, the same as hydroboost just with a different means of generating gain/boost. In a vacuum booster, both sides of the diaphragm are evacuated to whatever partial level of vacuum is being supplied by the engine, then when you apply the brakes, an air control valve is opened which allows atmospheric pressure air to enter the firewall side of the booster diaphragm(s) which creates a pressure difference across the diaphragm and causes the pushrod to be pulled forward towards the lower pressure side, assisting the driver.
Some simple descriptions of it below for those who'd rather trust some other random person on the internet:
http://www.agcoauto.com/content/news/p2_articleid/129
http://auto.howstuffworks.com/auto-parts/brakes/brake-types/power-brake2.htm
For the more video inclined:
http://www.youtube.com/watch?v=LThrL8Jjsgc
Tobin
stupidboy
stupidboy
My wifes porn star.
Morrisdale Pa.
I start the engine without my foot on the brake and as soon as the engine builds vacuum the pedal automatically goes toward the floor boards and puts the brakes on. Can't even move the truck then. NO AIR in the brake system. The air theory in the hydraulic system would not do this without foot pressure to activate the the imbalance in the booster. Some how there is there is more pressure on one side of the diaphragm. But what could cause this????
clarrance
While we are on this booster subject. What makes the brake pedal return to the proper position when the Bronco is cold, but once it's warmed up the pedal wants to only return 1/2 way back up. The brakes will have a slight drag and you have to pull the pedal back up with your foot.
Apogee
Tangent, OR
A bad air valve in the booster, allowing only forward side of the to get vacuum, or a plugged vacuum port between the two such that vacuum is never getting supplied to the back side of the booster and therefore no force balance is created. When you start the engine, the booster is finding a balance between the vacuum force and the return springs in the booster and MC.
Time to make sure there isn't a wasp nest or something on the backside plugging the air inlet, otherwise I think you need a new booster.
Have to agree with that.
Take the booster off and inspect it, but chances are that if it's old it's just worn out.
Is it original?
Probably the same thing as above. Just not quite as worn out. Sticks open a bit when it gets warmer, or perhaps just after getting flexed a few times it just can't come back to neutral anymore because some material is just tired from old age.
Same question then. Is the booster original?
Have you looked for any mechanical interferences? Something falling in the way of the pedal pivot or pedal-to-booster rod?
BigToe
Ah yes...the old wasp's nest in the brake booster trick, gets me every time.;)
clarrance
Paul,
the booster is brand new. The entire Bronco is brand new, every nut, bolt, bushing, screw, etc. I have checked and lubed all the pivots, bushings, linkages, etc. someone told me it could be the M/C not allowing the pedal to return. It's very strange.
