Vacuum Brake Booster Question
Mab1219
I am installing Toms Front Disc Conversion with vacuum power booster and am looking for advice on best location for vacuum line. Is it better to go to a manifold vacuum port or carb?? Does it need to pull a certain amount of vacuum? I have one port open at the base of the carb above the egr line...also have a port coming off a “tree” on the manifold where one line goes to the trans. Both ports are small and the vacuum booster hose is super loose on them without tightening the hose clamp... The Bronc is 73 with the original 302. Thanks so much for any help on this.
jrwyant
My '77 has a tree with the larger nipple on it, used by the vacuum booster. I expect that to be the "typical" configuration.
SteveL
Huge chevy guy
Hawthorne ca
I used the port on the rear base of the carb on mine. Keep the plug on the shelf for when you go hydro boost.
B RON CO
Statesville, NC
Hi, any large diameter port will work, under the carb, or on an intake runner.
Do not adapt it down to a small restrictive size.
Goggle some Ford engine pics and see how Ford did it. Good luck
Agree. And maybe you can even find a new tree with a proper 3/8" barb on it.
Does your carburetor have two of the larger 3/8" hose fittings? One at the base of the carb, on the common plenum in other words, should be for the PCV valve. The brake booster can come from any other one, whether on the common plenum, or a single runner.
As said, most of the ones I've seen from the factory were on the vacuum fitting, or "tree" at the back of the intake. But once intakes are changed out and aftermarket 4bbl carbs installed, most of them go to one of the two ports at the base of the carb.
Good luck.
M
Mab1219
Thank you all for the help. There’s only one large barb on the stock 2 barrel carb that goes to the Pcv valve the other is a small barb that I guess won’t work... the tree on the stock manifold only has small barbs so I guess I’ll need to replace it with one with an additional larger one. Thanks again.
