- Nov 3, 2003
- 51,618
Great looking carb by the way. And the whole engine as well!
And you're right, the stock '71 would not have had any vacuum systems attached to the air cleaner. Only later models got that. You would normally still have had the heat-riser tube to the snorkel, but nothing else.
Not aware of any factory PCV hose reproductions yet. I finally got a valve with the 90° 3/8" nipple and bent some tubing to get the cleanest routing to the new carb and simply used 3/8" fuel line to attach at each end.
Good luck. Looking great.
Oh, and glad to hear that I was wrong about the port. I was going to suggest just testing it when the engine was running, but it sounds like you got all the confirmation you need. And I agree that the vacuum brake booster should be attached to the manifold. I can't think of any other vacuum circuits needed on a '71.
