Vacuum Reading & Troubleshooting
Justafordguy
400-500 RPM in drive is a little low, mine will vibrate if I turn it down that low also. I keep mine at about 600 RPM and that smooths it out.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Here is a video of the Bronco idling in drive and accelerating. I think the first 30 seconds show the two issues but I recorded a 3:00 minutes with lots of stops, acceleration, and some cruising: https://youtu.be/DBrt_cxMzrk
Sorry for any shakiness and what not.
Rustytruck
Try setting the idle in gear holding the brake at 700 rpm. That will be about 900 in park.
Get a pair of insulated spark plug pliers. Start the engine in park and set the parking brake. With the engine running use your spark plug pliers and disconnect the wire from the plug. The engines idle should change. If the idle doesnt change something is wrong. With either the cap, the plug or the spark plug wire. Put the wire on and move to the next plug and do the same. Work your way around until you get them all.
Based on how its running in your viedo i would recheck the wiring, fireing order. It sounds like something is crossed up.
Pull number 1 spark plug passengers side plug closest to the battery. Turn the engine until you start feeling pressure. Then look at the timing and turn the engine until 0 TDC lines up with the timing pointer. Now remove the distributer cap. Note where the rotor is pointing and mark where it is pointing on the distributer body. Now put the cap back on. Note where the cap lines up with with the mark you made. That spot is number one. Follow that wire to the plug it is connected to. That should be number 1 plug. Pluga are numbered 1, 2, 3, 4, on the passengers side running from the fan end to the firewall. The drivers side runs 5, 6, 7, 8, from the fan end back to the firewall. If your engine is stock on the intake manifold you will see a list of numbers. That list is the firing order the engine runs on. Early 289 /302 used 1, 5, 4, 2, 6, 3, 7, 8. Starting at the cap the rotation is counter clockwise. Start at 1 and check the wire all the way to the plug. Then check the next wire on the distributer from left of number 1 see if it runs from that terminal to number 5 plug. Work your way around the cap and carefully trace each wire.
https://www.google.com/search?ie=UT...block+ford+firing+order#imgrc=NxySkmE8kvNXQM:
pcf_mark
Rustytruck has the best test for getting a lot of info very quickly. Two items I would check - check for a burned through plug wire the tick could be the plug wire arcing to ground. The other is to check where the distributor port(s) vacuum connectors go. Check that there is no vacuum at idle on the hose to the distributor. Just pull it off with the engine running and put your finger over it. With a C4 if the vacuum advance on the distributor is connected wrong you can get a huge rpm drop going from park to drive.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Update #1: The firing order was correct. I checked the wiring on the distributor to the engine and it did not match Rusty's order. After reconfiguring the distributor, I tried to start the engine and there was an obvious issue. I reordered the wires on the distributor for the "High Output" Firing Order (see attached) and it fired up with no problems.
Update #2: I started pulling the boots off of the spark plugs and I didn't get past the second plug when the idle didn't change. I think the cap might be bent; I am going to switch it out with another wire I have and continue to test the rest of the plugs (I would have gone through the rest of the plugs boots but I could feel my wife's stare through the garage walls).
Speaking of spark plug wires, the ones on my Bronco do not really match (i.e. different brands). I'd rather spend the extra few bucks knowing that the components on my engine compartment are new and reliable. Will any quality wire set work or is there a specific brand/model you'd recommend?
Rustytruck
The ford motorsport wires are reliable. But you have to know what distributer cap style you have. The female socket type or the larger top pin type cap. They use different style wires. Get the fitted wires so you dont have to cut and crimp wires. Take a look inside the cap for carbon tracking. Looks like pencil lines and short circuts the spark and causes missfire or cross fire on the spark. Scrub the inside of the cap with wd-40 and an old tooth brush. Then wipe out the wd-40 or spray out with good brake cleaner. Clean the rotor too. When replacing your plug wires look up on the internet how to tie up plug wires with zip ties. Cheap, effective and looks good.
jckkys
I don't know if the recording quality is the reason but the sounds I heard gave me the impression that there is an exhaust leak near the engine. Headers do make more noise, but that was very noisy. Another thing was the inconsistent idle. A broken spring in the centrifugal advance can do that. Remove the distributor cap and check it by turning the rotor counter clockwise. It should turn freely against the springs for about 5-10 degrees and snap back when released. It should always have some spring tension. If it's binding or if it turns with no tension, the spring may be broken. If doesn't turn freely against the spring a couple drops of light oil in the top of the upper shaft should loosen it up.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
September 2019 Update
You guys have been so helpful I figured it was only polite to give you a quick update:
1. Spark Plugs & Wires - I replaced all of the sparkplugs with Motorsports and swapped out any wires that looked worn or bent. I also checked the distributor cap per Rusty's recommendation and there were no issues there. The swap-out improved the condition of the idle and acceleration.
2. Rough Idle Issue - Although I've seen steady improvement with vacuum gauge reading, I was having a difficult time trying to fix the rough idle issue until I took the Bronco on the highway for the first time, which completely fixed the issue. The Bronco is running significantly better after a two-mile trip on the highway.
3. Engine Sounds - As mentioned on another thread, the weird ticking/flipping sound was coming from a header leak on the driver-side header nearest the firewall; I could feel air escaping at the same pulse as the engine. I replaced the header gasket and bolts, which fixed the leak and that weird ticking sound. Not only is the engine quieter it sounds SO much better as well.
Thank you for all of your help and insight!
Thanks for the follow-up. Glad it's running better again.
