Try setting the idle in gear holding the brake at 700 rpm. That will be about 900 in park.
Get a pair of insulated spark plug pliers. Start the engine in park and set the parking brake. With the engine running use your spark plug pliers and disconnect the wire from the plug. The engines idle should change. If the idle doesnt change something is wrong. With either the cap, the plug or the spark plug wire. Put the wire on and move to the next plug and do the same. Work your way around until you get them all.
Based on how its running in your viedo i would recheck the wiring, fireing order. It sounds like something is crossed up.
Pull number 1 spark plug passengers side plug closest to the battery. Turn the engine until you start feeling pressure. Then look at the timing and turn the engine until 0 TDC lines up with the timing pointer. Now remove the distributer cap. Note where the rotor is pointing and mark where it is pointing on the distributer body. Now put the cap back on. Note where the cap lines up with with the mark you made. That spot is number one. Follow that wire to the plug it is connected to. That should be number 1 plug. Pluga are numbered 1, 2, 3, 4, on the passengers side running from the fan end to the firewall. The drivers side runs 5, 6, 7, 8, from the fan end back to the firewall. If your engine is stock on the intake manifold you will see a list of numbers. That list is the firing order the engine runs on. Early 289 /302 used 1, 5, 4, 2, 6, 3, 7, 8. Starting at the cap the rotation is counter clockwise. Start at 1 and check the wire all the way to the plug. Then check the next wire on the distributer from left of number 1 see if it runs from that terminal to number 5 plug. Work your way around the cap and carefully trace each wire.
https://www.google.com/search?ie=UT...block+ford+firing+order#imgrc=NxySkmE8kvNXQM:
