Vacuum Reading Help
Epps1983
Clarksville, TN
Finally received my vacuum gauge and timing light, I removed and plugged my timed vacuum and plugged in gauge to full manifold at the base of the carb. I was really initially trying to see if there was a vacuum leak but the needle seemed steady. I took a pic of the gauge after it reached operating temp and the needle only had a bout a 1/2 in of movement in it.
Should I have kept the vacuum advance plugged in?
I'm working on doing the timing and adjusting the carb but didn't want to get ahead of myself if there was an issue here that needs solving first.
Cheers,
Shawn
broncnaz
At idle you shouldn't have any vacuum on the vacuum advance but its a good idea to plug it as you did anyhow for testing. Steady is good 1/2in. hg is not bad with some carb and or timing adjusting you should be able to get it steadier.
I would have to say that 14 is a bit low except for a more performance oriented camshaft.
A stock cam for example might give you a 20-22 hg vacuum reading at idle.
A very mild street cam might lower that to 18" or so. But less than 15 is likely to give you trouble with brake boosters and stuff like that.
It might also indicate other issues, but it's too early to tell that.
A really steady vacuum reading is just that. Steady...
When you said 1/2" did you mean a half an inch of needle movement, or half an inch of vacuum? If the latter, then yeah, that's pretty darn steady.
Keep playing around and let us know what you find.
Don't be shy about making adjustments or tweaking things here and there. That's the learning process. Almost anything can be reversed too, so if something doesn't work right, it can go back.
Epps1983
Epps1983
Clarksville, TN
Hooked the timing light up and she was set at 10 deg ATDC, loosened the dist and set it at 10 deg BTDC where the builder had a chalk mark. (Vacuum adv is still disconnected). After making the timing adjustment my vacuum increased to a steady reading of about 17, after adjusting the mix screws I brought it up to 18.
Yeah it's only moving a 1/2 in of vacuum not an actual 1/2 in. I didn't check for vacuum leaks because everything I've read says that a vacuum leak will cause the needle to bounce and be erratic.
broncnaz
A vacuum leak wont always make the needle bounce around. A small vacuum leak will increase idle speed and if its not leaning out the fuel mixture to much you'll never know it just by a vacuum gauge reading. But it will show up when you try to adjust the idle mixture screws and you find that you get very little to no change in idle speed when they are turned.
The small bounce you are getting could be several things bad valve seat, burnt valve, valve lash improper, or a small vacuum leak on one cylinder. Overall Id say your not bad off
73azbronco
A leak will actually make the needle steadier but lower as shown. Not saying that is the issue, other causes could be the reason, but 14 is low.
matts70
Northwest Indiana
So, your vacuum is bouncing something between 16 and 18 (give or take) when idling?
Driving, how is the acceleration and power from mid-throttle or full throttle? Does it grab and go, or does it feel like a comfy sedan making its way up to speed?
I see you have a Holley 4160 carburetor--how old is it and has it been rebuilt?
