I HAD a vapor locking problem, but no more! I too suffered from continual vapor locking in my 73. No matterwhat I did, I could not correct the problem. I tried new carbs, lines, mainifolds, cheap inline electric fuel pumps, return lines, and new tanks. The problem is Ford routes their small metal fuel line around and across the hottest part of the engine - between the hot air from the radiator and the heat from and engine.
I completely rerouted my fuel lines. First I purchased a decent rotary fuel pump from Mallory (120gph at 7psi) mainly to have a quiet electrical pump. I mounted it on the passenger side of the Bronco so that I could run the fuel line from the selector switch and across the transfer case crossmember. From there, I ran the fuel line up the frame and into the back of the carb - completely avoiding the front of the engine and the mechanical fuel pump.
As irony would have it, the day I did this conversion was on of the hottest days of the summer. I sat on I-70 in the middle of traffic for 1 hour in 103 degree heat while an accident was cleared off the highway. My bronco didn't spuutered the entire time
