You have to remove the main glass from the window, then the window felt top and along the sill, next on the periphery of the door frame there are small screws. There is also one large screw just below the pivot of the vent window. With Ll this out of the way, angle the vent toward the latch of the door. It should angle enough to get it out. I dont recall that I had to remove any of the other glass tracks inside the door, but all that was already out when I removed the vents. Make sure the main door glass is out of the door, otherwise it may be easy to chip it on accident as the vent is angled out. I dont think there is enough clearance, even with the window bumper removed and the glass sitting on the bottom of the door.
Once the vent is out, you have to remove the glass from the frame. Ive read some people used a heat gun. I used a razor and was careful with screwdrivers. I did end up chipping one...but I had already bought new glass for the whole truck, soI didnt care much. With the glass out, you can drill the rivets for the pivot bolt--available after market. To put the glass back in the frame there is a special tape-like gasket-seal. Some people have used tthe new resins, but I called a local auto glass shop, they installed the glass into the frames for me for a good price...only a couple of bucks more than what they were going to charge for the tape-seal itself.
It is a total pain in the ass. As I was doing a frame off, it was one of the more tedious sub-projects of the whole build. I powder coated the frames flat black and replaced the rubber, which was of somewhat dissappointing quality.
Good luck!
John
