DaveyGeez
gas cap
I'm not sure what happens to a response to this thread when three years have passed since the previous, but here goes. Finding this thread has made my day after having searched online for the past couple days.
I've been upgrading my My 1956 Ford Ranchwagon for the past five years thinking each year that it's finished. During this time I've noticed the pressure build up in the gas tank every time I open the cap and wondered why. Now I can account for it with three causes: the exhaust tail pipes are within an inch of the tank; the fuel return line from the FiTech EFI adds pressure; the custom 30 gal. gas tank has no baffles; the gas cap vents in one direction only, letting air in to replace fuel consumed, but not out for positive pressure relief.
That last item got me thinking about venting to a charcoal canister and set me on the path to this forum. A big thank you to every contributor for your logic and resources provided!
Now my question. Should I change to a completely sealed gas cap or stick with the one-way venting? Is negative tank pressure possible having a charcoal canister vent system routed from the filler tube a few inches below the cap and above the fuel return line (also fed into the filler tube), to the canister then to the air cleaner? If there is also a 12V purge valve included in the system there might be some negative pressure when everything cools down at night. This might cause starting problems in the morning so I'm thinking my one way vented cap might be the way to go.
Dave
1956 Ranchwagon; 302ci.; FiTech EFI; GearVendor overdrive; rack/pinion power steering & coil over shocks; Edelbrock intake/heads; Howard RV/towing cam....too much to list it all.
Dave
