Vibration - driveshaft discovery(s)
Lawndart
Noticed a slight vibration the other day; almost felt like a slight engine miss.
Time to park anyway as a dusting of snow was forecasted, meaning the salt life in the midwest.
I had some normal maintenance items to tend to, including wires, plugs etc. I thought that may resolve the issue. Nope.
After further investigation, I notice this...
This is the front of the rear driveshaft. Is there something hinky going on here?
bronconut73
Your losing needle bearings.
You may have caught that right before the major failure event...
Lawndart
Lawndart
Yep. Don't like the thought of major front ujoint failure.
But there is something else odd (if I read manuals properly) although I have run it as purchased for 30k miles (with normal greasing).
langester
MASTER OF MADNESS
I might be crazy but if that is the front of the drive shaft at the transfer case the drive shaft looks backwards to me. Is the double joint on the rear end?
Lawndart
Lawndart
When I first realized, I thought the same. But...
Lawndart
Lawndart
I think I've found your problem.
Someone thought they could eliminate the double cardan joint.
Well, they did it!
However, this was/is a smoooth ride. That is why I noticed the vibration early on.
So, do I order me up a Woods rear??
That is a U-joint yoke, not a CV yoke. The end of the yoke is squared off and the strap goes over the end of the cap. A CV yoke is rounded at the end of the cap and the bolt holes are more lined up with the bearings (and easier to distort the caps causing rapid needle bearing failure)
Needle bearing failure not related to contamination/running dry is generally overtightening of the U-bolts. Or a stretched/distorted saddle for the cap is next. The press fit into the shaft, those are the ones that live longest. Evenly supported.
Lawndart
Lawndart
Are you saying the PO also changed the output yoke on the xfer case??
Lawndart
Lawndart
Gods damn.... POs...
And, I removed a suspension lift (2ish) and returned to OEM height.
What were they thinking?
NC-Fordguy
Bethel/Greenville NC
I have somewhere, once again somewhere a stock spicer yoke. I can look around to see if it can be found tomorrow if you like. Cover the ride and it's yours.
half cab
Guru Bronco
I always just snug my bolts up not to tight.
Supposed to be about 15 ft.lb. Torque I believe but I havent went by that in some time.
Lawndart
Lawndart
Update -
Thanks everyone!
Thanks Broncobowsher for pointing out the yoke.
Thanks NC-Fordguy for the kind offer.
I pulled the d-shaft and replaced the u-joint. Installed. Runs nice and smooth again.
I did a visual on the particulars; seems all was intentional. The rear yoke is a spicer type and the rear is a spicer slip shaft. The front is a spicer double cardon shaft.
Current plans are to convert the rear back to a double cardon sometime in the nearish future.
Tailwinds
sprdv1
REBEL
makes a world of difference don't it.. Glad to hear it
