Vibration on acceleration
White Knight
When coasting.... all good, then I accelerate and get vibration. Checked engine mounts, just had drive shaft balance, wheel/tires rotated and balance still happening. Any suggestions?
Thanks is advance!
Rustytruck
check the CV centering ball inside the CV joint, bad or lost needle bearings. check the driveshaft splines for lube or stuck splines. might try removing the shaft and run off the front in 4wd high with hubs locked.
armynavy17
An unbalanced driveshaft should cause vibration any time it's spinning. My bet would be bad CV joint. Depending on what exactly is bad they can be rebuilt. I'd recommend taking it to a local driveshaft shop though, it's not as easy as replacing u-joints.
As said, pinion angle discrepancy can cause this. Old u-joints can cause vibrations too. Lack of lubricating them can speed up their old age arriving.
A stock shaft has at least five grease fittings you need to attend to. Some u-joints are non-serviceable so you would only have two grease points, with one of them critical at the centering ball area mentioned.
Does your Bronco have a suspension lift? How much and what method was used? If so it may need shims to correct the pinion angle.
Did the vibration just start recently after driving the vehicle for years? Or did it happen to start right after making some modifications?
If you're not sure about any of this, post up some pictures of your setup. Take one of the rear most u-joint and pinion yoke area taken from directly on the side. Not at some odd angle if possible.
If the driveshaft has not been serviced, it's time. You can try adding grease where it's needed, or you can simply replace u-joints if they're old. But checking before replacing, rather than replacing is usually a good practice.
If the shaft was balanced, the shop should have checked the CV.
Pinion angle too high, climbs under load and puts the U-joint in a bind.
Or an engine issue. Bad carb, misfire under load. Could also be ignition.
White Knight
White Knight
You guys are awesome! Rear u joint was bad.... one side had broken and all needle bearings were gone. Thanks for the quick feedback. I love when a fix is only $30 and 10 mins👍
2 things come to mind. Over tightened U-bolts on the U-joint. Crush the caps and the needles grenade.
The other thing is if saddles are bowed out.
And that happens a lot more than you might think. The torque on those nuts is not all that high.
Has it just been too long since they were greased? Or do you think something more nefarious was at work on the joint?
sprdv1
REBEL
I hear that... more often than not
