75Bronc
- Feb 5, 2008
- 425
I have just finished a drivetrain rebuild. I installed a ZF5 and 351W out of 1990 F250. I rebuild the stock J shift transfercase, used the BCB adapter kit with master and slave. I got new tom woods drive shafts, new exhaust. I had 4.88 motive gears sets installed, reused the rear Detroit locker and put a grizzly locker up front. All ball joints, u joints, axle bearings, tie rods are new.
Here is the problem. When I am driving with the clutch fully engaged, i have a slight vibration when i first hit the throttle or when I release the throttle to coast. There is no vibration during normal driving or take off, it is smooth as glass. Even at 75 mph its smooth. Its just when I hit the throttle or release the throttle. It is right at the beginning of the pedal. So if I hit the gas it only vibrates for the first tiny bit of pedal or when I release right at the very last bit of pedal. If I keep just the slightest amount of pressure on the throttle pedal it will vibrate until I give it more throttle or release. The Vibration feels like I hit the rumble strip on the side of the road.
I thought it might be my exhaust. I only have one exhaust hanger at the end of the tail pipe. It is a 2 into 1 exhaust I built. It seems a little loose where they come together. It doesn't look like it is hitting anything, but maybe there is a resonance or a vibration when the motor torques? I thought maybe it could be gear lash, but I felt the rear 3rd member and looked at the gear pattern, it was set up properly. What else could be causing this? I don't think it could be clutch related, the clutch should be fully engaged the entire time this is happening and it is smooth during take off.
Any suggestions or thought are appreciated. Thank you.
