Vibration
broncosam
Out driving the Bronco yesterday evening I started feeling a vibration (or something of that nature) at around 50 mph. No unusual noises but it could be felt. This morning I checked the torque on the wheels to make sure they were tight. Checked the rear driveshaft and all of it's fasteners. everything from the transfer case back is new, driveshaft, new 3rd member, new wheel bearings and seals in the rear axle and everything to do with the rear brakes is new as well. 3.5 inch lift with 6 degree shims at the spring pack. I do not have a front driveshaft in it at this time but I did check to make sure the transfer case was in 2H and not 4H or 4L. I took some pictures of the rear driveshaft would like some opinions about the angle if you can tell from looking at them. Sorry if the pictures are hard to see.
bmc69
Just from what I can see...your rear shaft angles look fine to me.
JSBX
What about u bolts holding spring pack to rear end housing. I had them loosen up after a few hundred miles after installing new springs.
All good points above. But did you also add “new schmew” to the list? Or should that be “new schmoo” instead?
In other words, new or not, did you lubricate all the driveshaft grease points?
That would be one Zerk in the rear, three in the front, including the female grease fitting in the middle at the centering ball and yoke.
Yes, they were probably lubed from the factory, and may even be the greaseless type that you don’t have to service ever. But it wouldn’t hurt to make sure.
And the centering ball is always greasable and usually gives the funniest vibration issues down the line.
Can’t hurt to double check.
kat
Bristol
When you checked your ujoints/driveshaft, did you have the tranny in neutral??? Chock tires, release parking brake and throw in neutral see if anything moves that shouldn't.
Jdgephar
Make sure to re-torque the leaf spring u-bolts after a couple dozen miles.
Sent from my SM-G981U using Tapatalk
B
broncosam
Sure did, and I re-checked the torque on everything I had taken loose or replaced, front and rear.
  • Sad
Reactions: kat
