I am almost done with the install. I had to notch the frame to clear the bracket and alternator. Also I have to remove some wheel well sheet metal. I still need some air inlet tubing and silicone connectors for the maf. It is not so pretty now but after I get it running I'll try to make it look better. I am running Trick Flow heads, stage 1 cam, and street heat intake. Also a 85mm maf, 75mm tb, 42lb injectors, pms tuner, 1 5/8 shorty headers w/ 2 1/2 exhaust into magnaflow 2 into 1 muffler. The Vortech is a V3si trim high output. I am taking it to Mustang Ranch in San Jose to get tuned as soon as I get it going.
