I thought these things would be the easiest part of my axle swap. I had a lot of trouble getting the retaining rings in the groove - i had to apply a lot of force to the u-joint area in order to get the ring in.
Once I got that solved, now I find the hub caps to be very hard to turn. I understand that that is normal with he premiums but the issue is while the drivers side locks in a 180 turn, the passenger side takes about a full turn to lock and when I unlock it it doesn't want to disengage from the axle shaft..
What did I do wrong?
