bannind
- Mar 24, 2005
- 612
Ok,
(302/c4-74)
So a few months back I go ahead and decide to change the tranny filter because I wasn't sure when the PO had changed it previous to me. Tranny was running fine at the time, other than a hard shift from park into reverse (I should have left well enough alone). After changing the filter and putting it all back together, I started getting some weird slippage when the tranny would go from 1 to 2 - it should shift to 2nd then it would shift back down to first like I was cranking on the gas, then back up to 2nd where it belongs. Fluid and everything was ok, so I just took it into a tranny shop and they did an inspection on it, they stated that 'it's just getting old' and I need to pay a minimum of $300 to have them pull it out and check it all over, of course it could be more than that, but $300 was where it would start. What bugged me was the mechanic wouldn't be very specific with what he felt was wrong with it, he threw out very vague diagnosis terms. Over all I really thought he was just trying to bs his way into some work. In the end as part of the 'inspection' they tightened up some belts and hammered out the pan so the gasket wouldn't leak. I realize and accept the fact that the tranny is getting old, but I thought the tech should have been able to give me a little bit better of a description on the problem. Also when I balked on doing any work on the C4, because I thought I might want to put an AOD in it, he went off on how there was no way I was going to put an AOD in a Bronco (which automatically pissed me off and convinced me it was time to leave.) If I pick up an 90 or so AOD and the rebuild kit along with the AA/D20 adapter, how much time should it take a skilled mechanic to go through the tranny and put on the AA adapter? I realize that there are variables, but I am just looking for a ballpark so I can do the math myself to see if someone is trying to back door me. Also, how many hours should it take a skilled person to go through the C4? I have a couple of mechanics that I like, but the trust isn't totally there. I know I can take out the C4, take it too a shop for them to work on, and then put it back in - of course with the help of beer and buddies, so I am trying to decide if that would just be the best course for the time being. Oh and regular use is maybe 20 miles twice a week while I am in town (work sends me away from home quite a bit) and I have no intention of crawling at the moment because it just isn't my cup of tea..
thanks,
dan
(302/c4-74)
thanks,
dan
