In re-doing my suspension I am installing a set of front shock hoops. I have them bolted up to the front spring towers and tack welded to the frame. I need to finish welding them up but had a question. I have my old Lincoln AC 225 amp stick welder and I have a small wire welder that plugs into a 110V wall receptacle and uses flux core wire. Will the wire feed welder with the flux core wire be enough to weld them up properly or would it be better to use the stick welder?
