Wet Sounds Sound Bar Under Dash
texhost1
Has anyone installed a Wet Sounds Sound Bar under the dash? It would be mounted in the same area that most people are installed their HVAC vents? I think this is about the cleanest (but expensive) alternative for front speakers with out cutting the doors or kick panels. Please let me know your thoughts. Thanks!
RedBank
That's the route I chose. Only minor issue I had was the long rubber wrapped wire (if powered sound bar) that's a combination of three wires (power, ground and aux input). I sliced into it to shorten the power and ground wires but was very careful not to cut the blue input wire.
I had to buy a pigtail to convert RCA outs from radio into one aux out for the sound bar. This pigtail is plugged into the front channel of the radio. Sounds great.
Sent from my SM-G781V using Tapatalk
clinem03
I mounted mine (wet sounds 6) under the OE rear seat, fits really well and is as hidden as it can be.
PDQ
Clinem03, thats what I was looking at as well.....do you run yours via bluetooth or is it wired?
clinem03
It is wired into a Retrosound receiver but I have been using the bluetooth connection from my phone direct to the wetsound bar as I am having some feedback issues when I try to use it from the receiver in the dash. I'm chasing other issues on the truck and this one is low on my priority list so I'll get to it at some point, but for now the bluetooth connection directly to the Wetsound bar works great. You may want to check out this thread - https://classicbroncos.com/forums/showthread.php?t=306271. The community was awesome in helping make the decision and there are lots of other great options from other members.
Here is a pic of the final set up:
beatlescott
I also mounted my stealth 6 under the dash like the one pictured above. I think it looks and sounds good in that location. Plus I thought it was easy to connect to the battery from there. My only complaint is that the stealth 6 isn't loud enough at 70 mph.
orygunbou71
Ashland, Oregon
How did you mount it to the bottom of the dash??
BGBronco
N A S H V I L L E
Tennessee
It looks like there are two versions, amp and no amp. I would only use this for Bluetooth audio. Safe to assume that you can hook the amp version to 'key on/off'? Thx
ngsd
I have not been able to do that unless I am missing something, I have to manually power it up.
BGBronco
N A S H V I L L E
Tennessee
Just looked up the directions, it requires that you push a button to turn on. At least it's on the front of the unit.
ngsd
Yes it is a real PIA that it does not come on with radio power and you have to physically power it up every time. Especially if it is out of reach. I am taking mine out and I do not recommend this as a solution.
clinem03
What are you doing to power it? I have to turn mine on manually
Yep, you have to turn it on manually. It’s not super ideal but with its auto shut off I don’t find it to be an issue. It’s so subtle that it’s worth it for me.
ngsd
I put the stealth 10 ultra HD in mine and now i'm taking it out. $900 for something you have to manually turn on every time you want to use it. I should have read the manual first but I would have never guessed that it would not have had a power trigger from the head unit.
