people,
this is an embarrassing post but i’m going to post it anyway.
somehow, I failed at a one-wire alternator installation.
i’m on my third alternator now looking for some advice or diagnostic to run or... someone to come over and buy me a drink or something.
here’s what happened:
I did the timing chain, cover and seal replacement in an early thread with lots of help from this forum
got through that.
swapped a WORKING alternator out that was old but I did it anyways because I was in there and because I am stupid
once everything was back together I noticed the voltage was low in the cab. I have modern gauges so I could just see it pegged to like 11.5 volts
tried to debug the new alternator and didn’t notice anything wrong in the wiring.. so I said no problem.. switch back to the old alternator... it didn’t work?
so I thought ok, some fuse or some misplaced wire or short, can’t be a big deal only 4 wires go into there. checked the grounds etc. nothing so then I got pissed
I decided to teach the truck a lesson and bought a 3rd ONE WIRE alternator. I wanted more amps anyway and i thought ok if the regulator might be the problem the. let’s get rid of that PoS too. I was sort of daring the truck not to work at this point and throwing the kitchen sink at it.
Some guys at WH suggested swapping the pulley for a two groove vbelt pulley to avoid squeaks on the new alternator - no problem I did that sounded good too just in case the truck tried to fight back again and squeak wfter the alternator was fixed. . also bought a nice CVF 302 alternator bracket that made it easy to get the belts tight etc. just in case I wasn’t getting a good ground to the block on the alternator bracket
so now i’m on alternator #3
twin v belts spinning fine
no juice?
battery and everything reads under 12 volts
I drove around, revving the engine thinking it might just need more rpm to excite the alternator.. nothing
I confess I did not read the alternator instructions because (im like that)
but for gods sake it has ONE wire and a pulley. wtf am i doing wrong?
anything obvious to check? is there supposed to be a ground on this second alternator or is the block good enough like your starter?
attached are the parts AND two videos where I use the voltage meter to test a few spots around the engine while it runs.
lot of work and not the result I was hoping for.
split my old starter solenoid apart during the process and ended up replacing that too. at this rate I will have a new but non working bronco one part at a time by end of august
any ideas will be appreciated
https://youtu.be/wIanrpi_Ytc
https://youtu.be/qDV-e5g53qI
parts are these:
https://www.cvfracing.com/stealth-black-ford-small-block-alternator-bracket-289-302-1969/
https://www.wildhorses4x4.com/product/Hi-Output_Alternator_130-Amp/Bronco_Starters
https://www.wildhorses4x4.com/product/Battery_Charge_Cable_AMG_fused/Bronco_Starters
https://www.summitracing.com/parts/SUM-G3949B
got through that.
no juice?
parts are these:
