WH PS bracket with 351 Explorer serpentine conversion
mgb0302
Has anyone here used WH part #2029 with an Explorer serpentine conversion on a 351? When I called and asked if the 302 to 351 PS pump adaptor would make 2029 fit, I was told "yes." However, after hours of trying to figure it out, I think I was given bad info.
garberz
Bronco Influencer
Conejo Valley, Ca.
#2029 would need to be modified to work on a 351w. The other bracket they now offer works great on both the 5.0 and 351w because it’s a one piece design that bolts to only the cylinder head, much like the stock Explorer PS bracket. I’ve installed a few of these now, it’s a great product and mounts the pump under the A/C compressor if you chose to run one.
https://www.wildhorses4x4.com/product/19201/newproducts-EB
Mark
M
mgb0302
GARBERZ- I had purchased a similar bracket from BC. I also purchased the Delphi pump with dual return lines from WH but the return lines were hitting my inner fender. I did not want to bend the lines on my new pump so I called WH and asked if their part 2029 would work and he said as long as you use the adaptor. So I have been fighting with 2 different puzzle pieces for days and now stuck with un-needed parts. Just wondering how people may have made part 2029 work with an Explorer serpentine on a 351.
Hey mgb, sorry you're having to fight this.
I don't think the standard 351 adapters are correct for the #2029, but I have not tried either, so not sure.
Any chance you have some pictures you can share? Either by posting here to your "garage" or "gallery" or even sending them directly to me at paulb@wildhorses4x4.com?
Anything you can get would be good.
And not to worry about the parts. If we sold you something based on incorrect assumptions on our part, we'll take them back for sure.
But let's see if we can get them to play nice together first. I'll look for some pics I have of what a local guy did with his 351/Explorer setup to see if I can find them (it was four or five years ago now I think). Maybe they'll be of some help.
And with luck some of the others that have used the #2029 on a 351 will chime in with their direct knowledge.
Thanks. And again, sorry for the hassle.
M
mgb0302
Paul,
Thanks for the help! Jim contacted me as well and I sent him the photo. I also posted a pic at the following link. Let me know what you think.
399strokerEB
Wasilla, AK
I want some info on the newer one piece bracket if you go that way. Not happy with my explorer pump, last I looked the description said 5.0 only.
Z Bronco
I have the WH #2029 setup on my 351W, I bought the upper idler pulley bracket from a member here on this board (it is taller to work for the 351W), it worked great. It took a few washers here and there to line up all the pulleys so the belt wouldn't jump, but no issues other then that with the setup. Hope this picture before the radiator hoses went on helps.
M
mgb0302
Z Bronco. Do you know if the upper idler pulley in your pic was specially made? The one that came with my kit did not line up with the hole in the head. I think if the bracket was re-engineered or maybe even an additional hole drilled in the existing kit, it may work with a 302 and a 351.
Anyway, I went ahead and installed the bracket I bought from BC. It required some mods to the PS pump return lines but I think it will all work out.
Z Bronco
The upper idler pulley bracket was made by a member on this board. It is taller than the one in the kit so the holes would line up.
