- Oct 14, 2004
- 5,001
Everything I've read says it should be somewhere 13.5 to 14.5. The target AFR on my setup is currently 13.5 and it runs right around that at idle, throttle it and goes down low 12's but will climb back up. Runs very good. The reason I ask is the system is showing yellow, which is caution for anything above 13. The only way the caution goes away is when the AFR is below 13. This is a self tuning system, the only thing I have touched is idle speed, I dropped it to 750. I read somewhere that for a larger cam it may need to add more fuel for smoother idle. I do have a larger cam but with the self tuning I would think it should adjust and not be giving me a caution. Anyway, what are thoughts? Should I adjust the target AFR or just leave it alone? Runs very good as it is.
