Mike Hewett
- Mar 1, 2004
- 358
Ok, here is the question I pose to all of you in bronco land... What new products or parts would you like to see for broncos that or are not available or could be improved ?
Mike Hewett said:Ok, here is the question I pose to all of you in bronco land... What new products or parts would you like to see for broncos that or are not available or could be improved ?
trailpsycho said:It would only be a clearance issue if you were 8+ft tall. If your head fits inside currently with a hard top or a soft-top, then you woud fit with the rack installed...as it would sit a bit above the hard-top/soft top. The windshield frame would just be like a front tie-in point...the weight would mostly be on the bed-rails...just like on a regular tubed rack on a work-pick up...instead of the mount points falling inside the bed, they would mount under the length of the soft or hard top using the existing holes. The gap generated by this plate...think extended angle would be universal around the entire mounting surface (top at bed rails and at windshield) so no fitment issues. Most door/top rubbers could withstand the additional ~1/8-1/4 inch gap generated by this spacer; same with tailgate. Would not affect the stretch of the soft-top. Follow me??
