WhatÂ’s that sound?!?
gorf
Hi all. Im still dealing with fresh restoration blues. After getting back on road I now have developed a new rattle/drone/whirl. Can't really describe it, not sure where to start. I've included a short video. It only seems to happen in 2nd gear plus and only with throttle. Any throttle, doesn't have to be a lot, as in barely cracking the blades and it starts. You'll hear it around 10 seconds in. I press and depress the throttle barely to make the noise. When making the noise, if I let off throttle it's stops, even if maintaining same speed (like going down hill). Can't even describe it to google it. Any thoughts or idea's? Pulling hair!
https://drive.google.com/file/d/1YcuIx9dVgRLhM5P-IHYzdIkH8Vpn8NvU/view?usp=drivesdk
blubuckaroo
Grease Monkey
Ridgefield WA
Sounds like a transmission bearing or gear. I've heard a chipped gear sound like that.
Just my curiosity...what transmission is it?
G
gorf
Electric Fuel pump in tank. Braided supply and return ran to regulator on firewall
helo-mech
Do you get the same noise while in neutral with a load on the engine? Can you manipulate the throttle while feeling all your spinning components? I will give a nod to the trans also though. I've lost a bearing in a trans that had a distinct whine under load. Check all of the under hood things and see if you can feel something off.
What engine and setup do you have?
G
gorf
331, long tube headers, us quick 1 controller, Holley terminator x, msd 6 ignition.
I'll haven't tried neutral, rolling with load. I'll give it a try.
helo-mech
Hopefully it will make the noise under load when not moving. Check your power steering fluid level as well. If you have a automotive stethoscope you can listen around the water pump too. I see you have AC so check your compressor too. Basically anything external that spins and then move to looking into ways to hear/check the internals.
G
gorf
Any ideas why only with any throttle? If it's transmission, would it stop without throttle? If I had a bad tps sensor, could that affect line pressure and could that cause any noise?
I can never get it to happen without driving. It's driving me nuts…
blubuckaroo
Grease Monkey
Ridgefield WA
I can never get it to happen without driving. It's driving me nutsÂ…
If a gear is damaged on the front of the teeth, the whine would be under load.
helo-mech
More speed and pressures on things can make something whine while under acceleration. Trans bearings can do the same; you'll hear them under power. but not off.
When you say I can never get it to happen without driving do you mean it has to be in gear and under acceleration only? Or have you not yet tried in Park and Neutral via the throttle under the hood.
G
gorf
Not in park. I'll try neutral Parked and rolling and report back. Appreciate the ideas.
blubuckaroo
Grease Monkey
Ridgefield WA
4r70w. Recently rebuilt, <3000 miles
Darned if that doesn't look like a manual shifter!?:?
Maybe some more familiar with that tranny will respond.
Maybe to could take it to an auto trans shop. I'm sure they would recognize the whine.
helo-mech
I missed the trans Recent REBUILD................
Check things in the engine bay but that does lead a little more like and internal trans issue. Hopefully not. Might as well check the trans fluid too.
Check the Speedo cable and make sure it is tight at the lower connection.
73azbronco
Rear u joints? or rear diff sound. I have a 2006 ranger with AT sounds like that. 145,000 miles so not to interested in digging into it. remove rear driveshaft, drive in front wheel drive mode.
Check that your transfer case is in 2wd first.
If not, do what 73 suggested and drive on the front shaft.
If it wasn't already suggested (I think it was?) look for ANYTHING that could be touching the body when you are under even that slight acceleration. Remove all the shifter boots to not only get a better listen, but to see and rule out any possibility of one of them touching the body.
Unfortunately with no floor covering you're going to be hearing a lot of things! Hopefully it's a mild something in this case. Like a rear u-joint or something.
Speaking of rear u-joints... What is your rear pinion angle looking like? Is the truck lifted? If so, was there any correction of the rear pinion involved? Even though yours is not the typical sound of a vibrating u-joint, it's surprising the range of sounds and feelings that a double-cardan joint setup can produce. Shocking actually!
With that sound, and with it only happening in 2nd gear, i would have sworn you had a manual transmission. But with an auto it's a more finicky detective task at hand.
Isn't that your other discussion thread on the sound? Yes, i see it is. You should not start two distinct threads on the same subject. Unless it was an accident from not seeing your new discussion show up, it's just confusing to have two separate conversations on a subject. We might miss something good in the other one!
And speaking of the other one, it's very common practice by the O.E.M's to put a fluid inlet on the bottom and an outlet on the top. Promotes purging air bubbles out more easily as the fluid flows and carries air bubbles with it better that way.
Probably other more scientific reasons (because it's the opposite of a radiator's flow for example) but that's what I heard a long time ago.
Good luck.
Oops! I see that it wasn't you that started the other thread. Sorry about that.
Now I gotta take out that fluid flow dribble and put it in the other one...%)
(edit: nevermind. It actually WAS you that posted the question about the fluid flow. Gotta get my p's and q's straight. Must be late...)
helo-mech
Can you confirm top line is return? I'm battling some heat issues and have seen conflicting reports. My top line goes to top of radiator, bottom of radiator goes to bottom of transmission. 4r70w out of 2001 Ford Explorer
Looks like there may be heating issues with the trans also?
G
gorf
Thanks all. Trying to figure out the noise I'm examining everything. The trans temp according to quick 1 is ~220, so wanted to verify the coolant hoses.
Otherwise the transmission has had no issues, shifts smooth, etc
I'll try the front dig option to isolate the rear diff. 2.5&#8221; suspension lift.
