marcussly27
- May 6, 2015
- 143
I have new 17x8 wheelsmith steelies on balanced 265 BFG "trail" terrains (more road focused over all terrains) which I'm running at 28psi per JamesDuff recommendations. 2.5 SL 2 BL. 4 degrees of caster with stock radius arms and 7 degree C bushings. I forget what my toe and camber are but both are slightly positive since my last alignment just a couple months ago. I have the new JamesDuff dual sport heim steering system installed TRO with a track bar riser bracket welded onto the axle. My track bar and drag link are perfectly parallel. Around 50mph, a very annoying wobble in the steering wheel appears and it's driving me crazy! From 70-80 it disappears. Other then this VERY VERY annoying issue she drives fantastic, tracks straight, and is a joy to handle.
What am I missing? In talking with JD they suggested the 28psi and also locking my tie rod in place, one heim rolled up and one rolled down to prevent it from rolling. I need to get some red loctite to do that otherwise when I lock in the jam nuts and bring the wheel all the way left/right it loosens and the roll is back in the tie rod.
Any suggestions are appreciated. Thanks!
